Old 10-20-2005, 02:51 PM   #1 (permalink)
Default Cruise Control
Hi....I just bought a 96 Discovery 2.5 tdi
It seems to have the switches etc but I cant get the cruise control to work. Am I doing something wrong or does it just not work. I get up to about 100 kms..... press what I think is the master on the console, then pull on the + switch under the RH side of the steering wheel but nothing happens... when I take my foot off the accelerator the vehicle slows down until I reaccelerate.
Ideas?
Mark of NZ is offline   Reply With Quote
Old 10-20-2005, 03:02 PM   #2 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
you probably have a cracked vacuum hose. very common problem.
Arsell
My Car Domain Site
llesra is offline   Reply With Quote
Old 10-20-2005, 04:17 PM   #3 (permalink)
I had exactly the same problem with my cruise control, it was the vacum hose just slightly cracked at the end.
I snipped off approx a 1/4 of an inch and put it back on, it worked straight away.
I hope its this fix.........
G'day
John.
johnjcoyle is offline   Reply With Quote
Old 10-20-2005, 08:50 PM   #4 (permalink)
Like everone else is saying, vacuum problem. Replace your lines then go from there. Grab a haynes or chiltons manual good info in them. Take a look on ebay for shop manuals also. Above all do not take it to the dealer. As some of these Rover Guru's. They know what to do.
jdool76 is offline   Reply With Quote
Old 10-21-2005, 04:09 AM   #5 (permalink)
96owner's Avatar
Just carry a knife in your truck because it will need to be cut like ever 2-4 weeks or so depending on how much you use your cruise control. But eventually it will be too short to still cut so that’s when you will have to replace it. I just learned to live with out cruise control.
96owner is offline   Reply With Quote
Old 10-21-2005, 07:52 AM   #6 (permalink)
beer drinking member
dent's Avatar
my cruise is toast too but it wasn't the vac lines... damn control unit went. dealer wanted $600 install... after market still $$.
dent is offline   Reply With Quote
Old 11-02-2005, 03:44 PM   #7 (permalink)
Default Cruise control
Thanks Guys.....
Took me a while to get back to the forum. In the meantime I have talked to the guy who the dealer sold it to me on behalf of. He said it would be the vacumn as well and undertook to fix it for me.
I am in New Zealand and last weekend the wife and I visited the daughter and her husband (and our grandkids) in Whakatane, Bay of Plenty. The son in law works on a diverse farm some 11,000 acres. He drove the discovery and gave us a grand tour including river crossings the works. Fantastic trip and the son in law was so sold on the dicovery that I think he may try and track one down for himself.
Old 11-03-2005, 12:42 AM   #8 (permalink)
nzoliver's Avatar
Gallery: 5
Default Cruise cont
Howdy from the South Island!
Ok, REPLACE ALL the hoses for the cruise including the 1 through to the brake pedal. If that don't work, the ecu is prob no go. Does the light go on the switch? If so, maybe hope for it!
nzoliver is offline   Reply With Quote
Old 11-03-2005, 03:13 PM   #9 (permalink)
Al's Discovery's Avatar
Default More on Cruise
Hi guys,
I have been following this thread with interest as I have had a similar issue. I have a 98 V8 Disco and have had the 'stealer' take me for a ride on the cruise being linked into the ABS sensor and the need to replace this sensor. Has anyone heard of this ( please bear in mind I am not a mechanic ). If possible, can someone post a photo of or descirbe the location of the vacum tube so I can check it myself? Many thanks
Al
Al's Discovery is offline   Reply With Quote
Old 11-04-2005, 12:01 PM   #10 (permalink)
surffx@hotmail.com's Avatar
Same here, replaced all the hoses except for the one that goes through the engine wall. Light comes on the main switch but still does not work.
surffx@hotmail.com is offline   Reply With Quote
