Old 05-05-2006, 12:26 PM   #1 (permalink)
Pulling out a Hummer
Default cruise control on 95
anyone know of any quick ways to fix cruise control?, the button lights up when i press it but it doesn't show any signs of working, all of the fuses are good also
itsarova is offline   Reply With Quote
Old 05-05-2006, 01:07 PM   #2 (permalink)
Vehicular Limitations Tester
I have the same problem with my 96' and can't figure it out for the life of me... Methinks it happened when I had a new engine installed.
DickVII is offline   Reply With Quote
Old 05-05-2006, 01:38 PM   #3 (permalink)
Check the vacuum line that goes to it. Mine did same thing, it was split. I cut back beyond the split and voila! Works again.
jhmover is offline   Reply With Quote
Old 05-05-2006, 01:41 PM   #4 (permalink)
Rocky Mountain High
Funrover's Avatar
x2.... that's how I fixed a buddies
Old 05-05-2006, 02:48 PM   #5 (permalink)
nzoliver's Avatar
Gallery: 5
Lightbulb Cruise cont
Hi from New Zealand!
Yep, split pipes all the way! I have 3 on my 300Tdi!! Damned hard to get to as well especially the 1 under the front to the pump.
Oh well off for a go at it..
nzoliver is offline   Reply With Quote
Old 05-05-2006, 04:47 PM   #6 (permalink)
Default Check the relay...passenger footwell
Mine wasn't working and as I recall it was the relay in the passenger footwell.
Wade
wade is offline   Reply With Quote
Old 05-06-2006, 12:43 AM   #7 (permalink)
AZROVER's Avatar
I have the same issue. Where do you get at this vacum hose from? Under the dash or from the engine bay? -thanks
AZROVER is offline   Reply With Quote
« All it is | air dam »
