Old 05-08-2005, 08:55 PM   #1 (permalink)
Default cruising whistling/ shock problem?
At around 55-70mph+ I hear a whistling/ scraping noise coming from down below I cannot figure out if its coming from the front or rear but im just begining to wonder what can be causing that..
Also the front right of the car is a teeny bit lower than the rest of the car.. Does this mean one of my shocks are going?/
-Militant Grunt
Militant-Grunt is offline   Reply With Quote
Old 05-10-2005, 04:56 PM   #2 (permalink)
*bump* any ideas guys?
-Militant Grunt
Old 05-11-2005, 07:35 PM   #3 (permalink)
AdrianS's Avatar
Hi Militant-Grunt,
Most DI's lean to the passenger side because that spring is a softer rating than the driver side so it wears out a lot sooner than the driver side. If $$ is a factor you could just get another driver side spring for the passenger side to even it out. Where in NYC are you and what year is your Disco? I'm in Essex county NJ.
Adrian Strata
www.4x4ag.com
98 DI
34x10.50 Simex JT
2.5" SR lift
Evo Kit
91 RRC parting out
AdrianS is offline   Reply With Quote
Old 05-11-2005, 07:57 PM   #4 (permalink)
Support Our Troops
apbtpetey's Avatar
I get the same noise in my 97 Disco
Only I am pretty sure it is from the rear driver side and it will happen at various times and speeds. Seems to stop if I apply the brakes
apbtpetey is offline   Reply With Quote
