Old 06-07-2006, 08:37 AM   #1 (permalink)
Default D1 4.0 to Bosch 4.6 switch & timing covers
I have a Bosch 4.6 that I am putting into the hole in my Discovery where a GEMS 4.0 sat for the past 8 years. I know about using the 4.0 flywheel and swapping the flywheel position sensor and bracket and I plan on using the 4.0 plenum, injectors, etc. I also realize I need to swap the one timing gear.
The questions are, is the timing gear sensor, the one in the middle of the front cover, the same on the 4.0 and the 4.6 or does that need to be swapped when I put in the 4.0 gear?
Also I know if I was swapping from a 3.9 I’d need to reuse the whole front timing cover do I have to do this with the 4.0 GEMS to 4.6 Bosch swap? If the answer is yes why?
I have the 4.6 cover, but my 4.0 one is dinged so if I could modify the 4.6 one I’d rather use it with the engine it came on.
Thanks.
JohnnyDisco is offline   Reply With Quote
Old 06-08-2006, 12:48 AM   #2 (permalink)
Magicly Delicious
Bene's Avatar
I recomend posting this on www.lrrforums.com
I know Frank 90 has done the conversion a couple of times and can offer some good advise.
Kevin
1994 Discovery
Old 06-09-2006, 06:14 AM   #3 (permalink)
Banned
You need to use the 4.0 front cover and cam sensor.
Hank is offline   Reply With Quote
