Old 01-20-2006, 01:35 AM   #1 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
Default Dead Instrument Lights
This isn't the same problem as the other light thread, so I decided to make a new thread for it.
For about a week, my instrument lights haven't worked at all. The park lights, headlights, and taillights all function normally, but none of the instrument lights (cluster, console, stereo) work.
All the fuses are good. I tested with a known-good headlight switch and dimmer switch, it's not those. I tested with an extra cluster (I'm starting to gather duplicate parts of everything o.O ) and it didn't light up, so it's not an issue with the cluster. Any ideas? Anyone have a wiring diagram?
Felix J. Lockhart
1995 Land Rover Discovery (Series 1)
FelixLockhart is offline   Reply With Quote
Old 01-20-2006, 07:22 AM   #2 (permalink)
These pretzels are making me thirsty
Private Iron's Avatar
Here is a link to download the workshop manual, should have wiring diagrams.
http://www.cannell.co.uk/Manuals.htm
past that, I am not a wiring genius by any stretch, so I couldn't tell ya what was goin' on.
I love it when a plan comes together.
'98 Disco LE- bone stock, but with aspirations
Private Iron is offline   Reply With Quote
Old 01-20-2006, 09:58 PM   #3 (permalink)
Tried that link, no wiring diagrams, and the manuals inside don't work. I have a copy of the manual-on-CD, but it doesn't have 'em either (unless they're exceptionally well hidden).
Felix J. Lockhart
Old 01-21-2006, 09:57 AM   #4 (permalink)
remember one thing if you have power and ground you still may not have enough wire to have amperage going thru it.
remember to use a socket like a brake bulb or something to make sure the current is strong enough.
Old 01-22-2006, 12:03 AM   #5 (permalink)
I own a test probe, I'll just use that if it comes down to testing the circuit itself. I'm really hoping there's something fairly easy I'm overlooking
Felix J. Lockhart
Old 01-22-2006, 08:14 AM   #6 (permalink)
Only diagnosis will get you thru this.
