Old 08-17-2005, 07:06 PM   #1 (permalink)
Default Dealership...
A couple of weeks ago I asked about my overheating problem while on the freeway with the A/C on. You guys told me that it's most likely my radiator and it needed to be cleaned. So A couple of days ago, I took my Disco to the dealership where I bought it to have some work done. I have a warrantee, and I want to get as much fixed and/or replaced as possible before the warrantee expires.
I didn't tell them I was told it was the radiator and needed to be cleaned...I wanted them to come to that conclusion...So anyways, everything is covered except for the radiator! Which is nice because it would have been insanely expensive.
So now, the problem: since the radiator cleaning is not covered, it's going to cost me $460 at the dealership. That is extremely overpriced right? I have never had radiator problems on any of my past cars, and I don't know if anyone besides LR can work on it for a better price...Anyone know??? I thought that radiator cleaning jobs were under $100 normally...Thanks.
AndrewBone is offline   Reply With Quote
Old 08-17-2005, 07:14 PM   #2 (permalink)
Super Moderator
Disco's Avatar
Find a local Radiator repair shop in your area to have a look at yours, and quote on any problems they find. You should be able to save heaps $.
Old 08-17-2005, 07:16 PM   #3 (permalink)
4x4 Adventure Gear
John C's Avatar
New original rad is $379 for the DI. Don't bother having it rodded, better off replacing with new one.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 08-17-2005, 09:00 PM   #4 (permalink)
TerryS's Avatar
Any radiator shop that really knows their stuff should have the experience to tell you that rodding a land rover core is fruitless, if not a total waste, as the core passageways are too small to effectively clean them by a mechanical means such as rodding. The only method which really works, and will only work if the radiator has not long been fouled, is a mild acidic flushing. A standard core, in new condition should be able to flow check in the range of 24-26 gallons per minute. When the flow becomes constricted to a rate of less than 18 GPM, you will see heat rise (lack of heat dissipation). Oxides and mudding will eventually become too solidified to be removed by flushing, as all the flushing fluid goes through the more open cores, continuing to clean them and virtually bypassing the cores most solidly plugged.
A while back I took my radiator out, ran a flow check and found it was about 16-18 gpm, had is flushed will acid (about 15% muriatic acid) and got back to 22-24 gpm. The shop charged me $65. (that included pickup and delivery)
TerryS is online now   Reply With Quote
Old 08-18-2005, 01:21 AM   #5 (permalink)
how old is your beast mate?
disco-joe is offline   Reply With Quote
Old 08-18-2005, 10:52 AM   #6 (permalink)
99 DI with 86,500 miles on it...
Old 08-19-2005, 08:21 PM   #7 (permalink)
Black Magic's Avatar
What PSI/kPa is used for the water to test this?
Black '02 Discover SII, Auto.
Black '87 Suzuki Samurai, rock crawler :
Black '94 Discovery SI V8i, 5 spd (Currently DOA)
--## If you have enough time to do something over again, you had enough time to do it right the first time. ##--
Black Magic is offline   Reply With Quote
