After having replaced most of the stuff mentioned above, And it all needed it.... I STILL had the death wobble...
Mine turned out to be caused by a stuck adjuster on the track rod keeping the adjustment from being correctly made.. It was either toed too far out or too far in.....like 3/8 of an inch.
When I finally got the track rod where it could be adjusted and the front wheels aligned correctly. The wobble went completely away..
So. Check all that stuff. Free movement is NOT good.. Mine is down to zero now.. Steering wheel moves.. Wheels move... But the death wobble was caused by alignment in my case...
Definately check all the tie rod ends.. There are four.. Three right hand thread and one left hand...Panhard rod bushings keep the front end from moving L/R as it goes up and down...
Check the bolts holding the steering box to the frame.
Especially go over the steering colum ujoint bolts.. You need to get that play out of there...
But, First, Check the alignment.. I took the front wheels off and measured the front and back sides of the brake rotor with a tape measure.. When correct I was I believe spliting 53.5 inches.. The back side a hair under, The front side a hair over...I hope that measurement is correct.. Whatever yours is they should be essentially the same just front over back under..Split whatver line you get...Do this FIRST...
Good Luck
John
