» Sponsors
» Sponsors
Old 10-13-2009, 01:17 PM   #1 (permalink)
ihscouts's Avatar
Default Developing negative camber, how to fix?
I've been noticing that my passenger front tire is wearing and feathering on the inside edge. It looks like I'm developing negative camber http://www.jackit.com/bushings/image...xplanation.jpg I've gone through the RAVE an no mention of alignment is made. Anyone know how to fix it home style? What do I need to do to correct?
97 D1 SD
ihscouts is offline   Reply With Quote
Old 10-13-2009, 03:24 PM   #2 (permalink)
Ian Matthews
p76rangie's Avatar
Are you sure it is not just a wheel alignment issue
Old 10-13-2009, 03:39 PM   #3 (permalink)
how do I change this?
mbrummal's Avatar
It is probably a problem with toe-in (tho only thing you can adjust) If it is really negative camber, you could have a bent axle housing.
Mason
'00 DII, $G Front Bumper, Hella 4000s w/HIDs, TW Front DS, "Custom" Exhaust work
(from someone on Bimmerforums)
mbrummal is offline   Reply With Quote
Old 10-13-2009, 05:06 PM   #4 (permalink)
ihscouts's Avatar
I wondered if toe-in would cause this. If it's a bent axle housing that would suck. I'll check the toe-in and report what I find.
97 D1 SD
Land Rover developing new 7-seater Administrator Land Rover News 0 06-24-2008 10:23 AM
smoke test negative drum655 Discovery Series II 10 11-07-2006 09:28 PM
Maximum Negative FMFR Correction Fault p1177 Thomasmacer Range Rover P38, Mk III and Range Rover Sport 4 09-11-2006 07:20 PM
Positive Camber? braganjackson11 Series Land Rovers 1 05-11-2006 11:08 AM
Positive or negative grounded in '98 p38 ? onlyforlr Range Rover Classic 3 03-20-2005 02:21 PM
