Old 11-16-2004, 06:47 PM   #1 (permalink)
Default Different Location Of Fuel Pump Relay?
alright guys..i'm totally mind boggled here...i'm trying to replace my fuel pump relay but its NOT where it's supposed to be..i have the chart, and there are like 3 relays that are not there...i've look all around on passenger kick panel..and even the driver side...no luck...i've been looking for about 4 hours now....no luck...any help is appreciated...
1997 Disco SE -Forest Green
K&N Air Induction System
RoverTek Performance Computer
BORLA Exhaust System
OME H/D Shocks
31'' Good Year Wrangler MT Tires
RoverTym 2'' Lift Springs
Kenwood MP3 Player
Kenwood 800W Amp
2 10' JL AUDIO Sub's In Custom Box
In Car DVD System W/ 3 6.5'' Monitors
1990 Nissan Twin Turbo 300ZX 700HP
1992 Nissan Non Turbo 300ZX 300HP
Toddicus is offline   Reply With Quote
Old 11-16-2004, 11:27 PM   #2 (permalink)
I'm pretty sure that the Fuel Pump relay lived on a metal bracket that is situated behind one of the kick panels.
Wes DownUnder is offline   Reply With Quote
Old 11-19-2004, 11:42 AM   #3 (permalink)
I thought it was in the engine bay bolted to the bulkhead.
Lynall
lynall is offline   Reply With Quote
Old 11-19-2004, 06:49 PM   #4 (permalink)
The inertia switch is bolted to the bulkhead behind the washer bottle, it doesn't take much to set them off either.
Old 11-20-2004, 09:05 PM   #5 (permalink)
Hey Toddicus, remove your passenger-side kick panel "screw" or "screws", if you can call them that. They are the short plastic fasteners that hold the kick panel cover in place. I think that you can unscrew them w/a dime or a penny similiar to the way as the drivers side fuse box cover opens. The kick panel cover is a trick to get out, but once removed you will see all of your relays. If you have a map of those relays I would like to get a copy, if at all possible. Good Luck, and Thank You, LRW.
LRWheelman is offline   Reply With Quote
