Old 05-19-2005, 04:16 AM   #1 (permalink)
downunderdisco's Avatar
Question disco 1 drainage holes in doors
[font=Garamond][size=7][color=Black]I noticed water dripping down on to the sills below my drivers door. I pulled out the little rubber plugs and about a litre of water came out. I pulled the stoppers on the rest of the doors with the same result. Are these meant to be left in or out or should I drain them after rain. I live in Perth Western Australia so thats not to often.
downunderdisco is offline   Reply With Quote
Old 05-19-2005, 04:43 AM   #2 (permalink)
I live in Perth and found the same problem about 10 years ago, don't know why they were put in like that. I took them out and if I am going bush, just put masking tape across them till I get back to stop the dust or water getting in .
aussie disco97 is offline   Reply With Quote
Old 05-20-2005, 06:34 AM   #3 (permalink)
Default Electric windows aswell.
I think i'll use your masking tape idea they look like they would be a pain to constantly fit and remove. Probably responsible for my intermittent rear electric window problem. If you hit a bump the windows stopped working then would be ok in a couple of minutes once the water drops dried.
Old 05-20-2005, 11:21 AM   #4 (permalink)
WetDawg's Avatar
Default plugs?
Exactly where are these plugs located?
WetDawg is offline   Reply With Quote
Old 05-21-2005, 08:02 AM   #5 (permalink)
Default plug location
The plugs are located at the base of the doors on the inner door skin. They are about 10mm round and dome shaped there are 3 in the front and 1 in the back the rear door doesn't have them as the rear window is fixed and sealed.
