» Sponsors
» Sponsors
Old 10-31-2009, 04:55 AM   #1 (permalink)
Daniel Cullender
Default Disco 1 not starting after heavy rains
Hi,
I got caught with my Disco 1 V8 petrol in some really heavy rains last night on the way home. This morning, when trying to start the car, the engine turns normally, but never starts.
I have checked the distributor cap and a couple of electrics and all looks fine (ps I am an amateur w.r.t to mechanics). I can see there is a lot of dirt all over the engine components, so it seems like water may have gotten somewhere it should'nt.
Should I just leave it to dry out?
Any idea's / suggestions would be greatly appreciated.
Thanks in advance
cullendw is offline   Reply With Quote
Old 11-01-2009, 09:23 AM   #2 (permalink)
Daniel Cullender
After checking all the possible components that could have been affected by the rain, it turns out that I had a loose connection on my Ignition Coil (I had done some hard 4x4'ing earlier that day which may have caused the issue)
Old 11-01-2009, 12:59 PM   #3 (permalink)
So I took your advice and check the connection on the Ignition coil, it seemed fine. I found a thread on discoweb about checking if the engine was flooded, to clear the cylinders they mentioned pulling the fuse for the pump and running it until it idles and dies out and throw the fuse back in... So I did that and it started, drove it around and it continually starts right up. I am still determined the original problem is moisture/water because of how many times it shows up right after it rains. I am going through everything with dielectric grease but would appreciate any further advice on what could be happening...
vonbrandt is offline   Reply With Quote
Old 11-01-2009, 03:14 PM   #4 (permalink)
yesmar's Avatar
im having this same problem with my 79 mercedes its a carburetor. on a sunny day i leave the hood open a bit and it fires right up
"I should never, ever, ever be allowed near my car with any sort of tool."
yesmar is offline   Reply With Quote
Help! Disco I, Late II or Lanc Cruiser Evoking Discovery Series I 7 08-18-2009 09:20 PM
Should I buy a 97Disco or a Disco II? keroppi Discovery Series I 9 07-21-2009 05:51 AM
My trail-ready Disco I for your stock Disco II chelo Land Rover Vehicles 0 11-18-2007 10:55 PM
LR Disco II Starting issues? LRDisco2001 Discovery Series II 5 08-03-2007 01:21 PM
Pre-95 Disco Newbie needs more advice pfkb72 Discovery Series I 18 09-12-2005 10:49 AM
