» Sponsors
» Sponsors
Old 04-20-2008, 08:17 AM   #1 (permalink)
rover42's Avatar
Default disco 1 turns over no fire
IT HAPPENED LAST NIGHT, DROVE 20 MILES TO A LACROSS GAME, RUCK SAT FOR 3 HOURS, GOT BACK IN AND NOTHING, IT JUST TURNS AND TURN AND TURNS, IT SEEMS TO HAVE NO SPARK. I HAVE PRESS IN FUEL RAIL. FUEL PUMP TURNS ON, BATT. HAS FULL CHARGE.
97 SD DISCO 1 WITH STICK.
rover42 is offline   Reply With Quote
Old 04-22-2008, 08:18 PM   #2 (permalink)
AFIROVER
afirover's Avatar
try and see if the mutifuntion relay on the pass side under the hood and looks like a black box about 3.5-4 " wide by 1.5 deep or thick has two plags on it unplug and reconect and see if that helps sometimes but not every time
this unit controls the fuel pump .......
hope this helps
afi
afirover is offline   Reply With Quote
Old 04-23-2008, 05:53 AM   #3 (permalink)
rover42's Avatar
thanks but the fuel pump works like a champ, i think i have naroowed it down to te ecu.
Old 04-23-2008, 06:05 AM   #4 (permalink)
Elemental's Avatar
http://www.landroversonly.com/forums...nciples-23603/
Old 04-23-2008, 07:13 AM   #5 (permalink)
Deployed OIF
ArmyRover's Avatar
Confirm this tidbit first before jumping on the ecu. ECU failures are not real common unless your leaving out the part where you submerged it in water.
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
Old 04-23-2008, 07:27 AM   #6 (permalink)
rover42's Avatar
Thanks Guy's I Have Looked For A The Same Stuff. I Have Plenty Of Fuel Press. The Intake Is Clear, My Timing Is Or Should Be Right On. I Just Have No Spark. I Jumped To An Ecu Conclusion Because My Check Engin Light Is Always On Do To A O2 Sensor, Now When I Turn The Igntion On The Check Engin Light Does Not Show At All. Plus I Have To Have The Key In The On Postion For 5-8 Sec Befor The Motor Wil Start To Crank.
Old 04-23-2008, 07:43 AM   #7 (permalink)
Elemental's Avatar
Your security computer needs to be synced with your engine computer. That has to be done at the dealer using testbook. Rover had a TSB about this.
Old 04-23-2008, 08:36 AM   #8 (permalink)
Deployed OIF
ArmyRover's Avatar
What Elemental said....
For the love of God would you quit CAPITALIZING every damn word. Your giving me a skull cramp. Thank you that is all.
89 Jaguar XJ6
Old 04-23-2008, 01:12 PM   #9 (permalink)
rover42's Avatar
sorry armyrover, lol i had my freind that is the lead tech at my landrover dealership come over and he told me the same thing about the security lock out. THANKS all for the help AND THE SKULL CRAMPs..
Old 04-23-2008, 02:48 PM   #10 (permalink)
AFIROVER
afirover's Avatar
I can tell you how to go around it in a pinch BUT I will not post it on the web
call me for details afi
317-294-0071
Old 04-23-2008, 05:05 PM   #11 (permalink)
rover42's Avatar
Thanks AFI i will call you later for the info, THANK YOU VERY VERY MUCH.
Should I buy a 97Disco or a Disco II? keroppi Discovery Series I 9 07-21-2009 04:51 AM
My trail-ready Disco I for your stock Disco II chelo Land Rover Vehicles 0 11-18-2007 09:55 PM
Pre-95 Disco Newbie needs more advice pfkb72 Discovery Series I 18 09-12-2005 09:49 AM
Help empty my garage! Ton's of parts.. RedRhinoProducts Land Rover Parts and Accessories 9 05-11-2005 01:25 PM
new guy looking for mid 90's disco and info tire General Land Rover Discussion 2 10-10-2004 07:11 AM
SEO by vBSEO 3.3.2
