» Sponsors
» Sponsors
Old 12-05-2004, 06:29 PM   #1 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Question Disco Diff Lock Seized How to ........
Hi there and Happy Holidays from Adam in the Big Apple.
I have a 1996 Disco I with the seized Diff Lock.
Two questions: If anyone has been able to free it, how ? How do you remove the knob without making a mess and ruining the woodwork?
Thanks in advance.
Old 12-06-2004, 09:47 AM   #2 (permalink)
Administrator
Common problem, having the shifter not move to the CDL side. You ar going to need to clean and lube the t/case linkage from the bottom and most likely the top. Be careful not to force the shifter, you can bend the linkage. To remove the t/case shifter, I believe you just pull up on it, I don't think your screws off. The trans. shifter knob come off by pressing in the shift button and pull up hard.
Good luck,
Mike J.
Old 12-06-2004, 09:41 PM   #3 (permalink)
I freed my own, and several others with just a firm wiggle, while rolling forward at a slow speed (0 to 5 mph) in neutral. Lube is always good, too! Mine now moves quite freely, works real well. . . . .I strongly recommend engaging the low range & diff-lock operations of your Rover on a monthly basis at least, just to keep things moving freely. It's also a good excuse to get off road on a regular basis. Thank You, LRW.
LRWheelman is offline   Reply With Quote
Old 12-08-2004, 05:59 AM   #4 (permalink)
John C's Avatar
Adam, if you need any help just let me know (I work downtown by the WTC).
John C.
Old 12-10-2004, 01:40 PM   #5 (permalink)
Professional Yorkshireman
Bush Tucker Man's Avatar
Good evening Adam from across here in England
Try this link, it ought to help
http://home.twcny.rr.com/eeibooks/ro...codifflock.htm
Richard A Thackeray
Yorkshire Born & Bred. And Proud Of It
Defender 110Td5 'Heritage'; S50 RAT
Jaguar XKR; X88 JLT
"Stop The Press!!, Website Updated On; 8th August 2008"
"You Can Allus Tell A Yorkshireman, But You Can't tell Him Owt!"
Bush Tucker Man is offline   Reply With Quote
Old 12-12-2004, 06:12 AM   #6 (permalink)
The Urban Motorist
Thumbs up Thank you all for your swift replies.....
Sorry but things have been hectic over at the job ( a real saltmine, I work EMS at Central Booking). Many thanks and I will let the list know how I fare with this little bugger.
SEO by vBSEO 3.3.2
