Old 01-04-2008, 03:23 PM   #16 (permalink)
natvboy's Avatar
Was merely posting something I saw in regards to Neapco u-joints. Was wondering if anyone else had problems with Neapco u-joints? I would assume the caps were the part that mic'd smaller than stock but am unsure.
"He who has a 'why' to live, can bear with almost any 'how'." - Friedrich Nietzsche (1844-1900)
natvboy is offline   Reply With Quote
Old 01-05-2008, 07:34 AM   #17 (permalink)
antichrist's Avatar
From Spicer and Neapco catalogs.
5-4x ---- BEARING CAP DIA. --- 1.0630
1-0005 - BD ---------------------- 1.063
No matter what u-joint you mention, you'll always have someone who's had a problem. There quite a few variables in u-joint installation that affect longevity. For instance, the person who had one installed in Oct may have erroneously assumed the grease that came in them was fine and he didn't need to flush it out with proper grease for in use service. A snap ring may not have been properly seated. A needle bearing may have been lost during installation. Just a few possibilites.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1
95 D90
Old 01-05-2008, 08:20 AM   #18 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Originally Posted by sideview View Post
I don't understand what your asking, are the actual joints smaller or the caps?
The trunnion ends where the cap rides is where the issue is. I opted not to risk a failure on the trail and go for the oem joints with the bigger ends. GBR is the next step as funds allow.
As for the Spicers, check your local driveline shops, they should have them in stock. Like antichrist said though the manufacturing has been farmed out to (?).
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Old 01-05-2008, 08:39 AM   #19 (permalink)
antichrist's Avatar
I don't have the OEM dimensional data, but I'd be very surprised if they are larger than spicer/neapco/precision u-joints, since all three mfg list their respective u-joints as fitting the Land Rover application.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1
95 D90
Old 01-05-2008, 09:06 AM   #20 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Just took his word on it, as he mic'd them and said they were significantly smaller than what he took out, and said he wouldn't risk running them in his own vehicle(you can visually see the diff.).
They were bought at his shop and returned at his shop, and he also took the time to remove both joints(free of charge), so he wasn't making any money by sending me away.
The 3 joints listed above are of 3 seperate and different designs for the same application. Not trying to start any conspiracy theories or arguements, just sharing my personnal experiance.
1997 Disco 1
2000 Disco 2
www.mvlrs.com
ON WISCONSIN
Old 01-05-2008, 01:22 PM   #21 (permalink)
antichrist's Avatar
Hmmm...well, I have a DII front shaft here to rebuild, guess I'll do some measuring when I tear it down.
FWIW, I have rebuilt them with Neapco u-joints (as well as with Precision), and if they were "significantly" smaller, they wouldn't have fit properly (ie. needing to be pressed in), which they did. I don't have the old caps, but the next one I rebuild I'll mic them.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1
95 D90
Old 01-05-2008, 02:49 PM   #22 (permalink)
sideview's Avatar
Yeah, I'd be curious to find out the measures. The Neapcos barely fit as is. Can't imagine how they would fit at all if much bigger.
"From 30,000 feet that swamp looks like a nice green lawn."
Hoho Lickin' Kitty Blingin Carpet Muchin Floor Moppin Bubbleheaded Vixen
sideview is offline   Reply With Quote
Old 01-05-2008, 05:59 PM   #23 (permalink)
antichrist's Avatar
Badger, now that I think about it, are you talking about the bearing cap diameter, or the cap to cap dimension?
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1
95 D90
FRONT DRIVE SHAFT '04 DII 54k miles DevilDisco Discovery Series II 15 04-30-2007 07:02 AM
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 06:33 PM
Front drive shaft check? drum655 Discovery Series II 12 05-02-2006 05:23 AM
WTB Disco II Front End Parts Ike Land Rover Parts and Vehicles Wanted 3 08-22-2005 05:59 PM
99 Disco Front drive shaft failure Norwestdisco Discovery Series I 2 09-06-2004 09:30 PM
