» Sponsors
» Sponsors
Old 07-02-2009, 07:32 PM   #1 (permalink)
Default Disco Started. Idle Problems.
Finally got Disco started, and new problem presents. The car is idling very rough, and also accelerates sporatically at lower speeds (between 10-30mph).
Error Codes:
P0123 (Throttle Position Sensor High Out of Range Fault)
p1447 (Evap System Purge Valve Open or Short Circuit Fault
TPS unit tested fine, maybe the wiring?
Any Idea's?
-99 Disco I
98k Miles
"Where were going, we don't need roads"
JohnnyMax05 is offline   Reply With Quote
Old 07-06-2009, 10:26 AM   #2 (permalink)
Nothing?
Guess I'll replace the whole Unit.
-99 Disco I
98k Miles
Old 07-08-2009, 12:21 AM   #3 (permalink)
ihscouts's Avatar
What condition are the vacuum lines under the hood? I think you might have a vacuum leak.....
ihscouts is offline   Reply With Quote
Old 07-08-2009, 08:23 PM   #4 (permalink)
The Vaccum Hoses were replaced a few months ago when the old ones pretty much rotted off.
-99 Disco I
98k Miles
Old 07-08-2009, 08:31 PM   #5 (permalink)
Also when i first tested the TPS it seemed to be working okay. I retested it a few days ago and it was completely fried. the truck will now stall out after about ten seconds if i keep the TPS connected, with it disconnected it runs, but the idle is sporatic and rough. I just ordered an entire throttle body, TPS, and IACV, and will replace all of these to see if it corrects the problem.
**A new unrelated problem: the fuel gauge is stuck on empty after filling car. I disconnected the fuel sender unit and it looks like the connector is corroded pretty badly, so ill replace the entire fuel pump wire harness sometime next week.**
Its been a week of ups and downs, fixing one problem only to have another present itself.
-99 Disco I
98k Miles
disco 1: misfiring/loss of power/high idle disco stu Discovery Series I 10 12-17-2008 10:34 AM
97 Disco low idle issue... timkel74@msn.com Discovery Series I 8 02-12-2008 06:39 PM
Idle problems DougG Range Rover Classic 12 06-10-2007 01:58 PM
Idle Problems!!! ZAD329 Range Rover P38, Mk III and Range Rover Sport 5 04-07-2006 01:04 PM
Common Disco 1 problems Beirut_Rover Discovery Series I 3 05-19-2005 10:25 AM
