Hello,
Have you tried this web site http://www.remotekey.co.uk/Batteries.htm I used these instructions to reset the remote for my 300Tdi. If this does not work you can contact then and see what they say. Hope this helps. |
HANDSET INITIALISATION
New handsets are supplied in pairs. If a new handset is required, it will require initialisation to the Theft Alarm Unit (Z163) using the following procedure: 1. Starting conditions: ignition off, doors unlocked, bonnet switch depressed. 2. Carry out instructions 3 to 9 within 8 seconds. 3. Switch ignition ON. 4. Switch ignition OFF. 5. Lock doors. 6. Unlock doors. 7. Release bonnet switch. 8. Switch ignition ON. 9. Switch ignition OFF. If alarm is correctly accessed, horn will sound and LED will light. It is now possible to programme two handsets of correct frequency to vehicle alarm ECU. This must be carried out within two minutes. 10. Press and hold down button on first handset until dash LED flashes. 11. Repeat instruction 10. for second handset. 12. The LED will extinguish if both handsets have been initialised correctly. |
