Old 11-16-2004, 06:55 AM   #1 (permalink)
Smile Discovery just stops
Help
My 96 300 TDi just stops for no reason when I am driving ( just like you had turned the key of ) It will not start again for about 5 mins or so and then will run ok for another few days sometimes even a few hundred miles and then do it again. We have had a look and dont think is dirty fuel. the Discovery is serviced evert 5000 miles and filters changed
theitguy is offline   Reply With Quote
Old 11-16-2004, 03:40 PM   #2 (permalink)
How about the fuel pump or more so the fuel pump relay??
Mike J.
Old 11-17-2004, 02:11 AM   #3 (permalink)
Default Thanks
Thanks I will try the relay ( think we did look at the pump but never thought about the relay )
Old 11-19-2004, 11:38 AM   #4 (permalink)
TDI has mechanical lift pump so has no fuel cut out relay!.
Look at back of injector pump if it has a single wire to the stop solenoid check the connection, if no better remove stop solenoid check for swarf (if any inj pump u/s), remove plunger and spring from stop solenoid and refit and test drive if prob has gone away either your stop solenoid is u/s or you have a wiring fault.
If you have more than one wire going to the back of the injector pump you will have the later immobiliser system which is famous for an item called the spider unit failing,the spider unit which is the immobiliser brain and is buried deep in the dash but is not to bad to change although i have never done it!
If none of the above cures it you will have to start on the fuel system.
Lynall
lynall is offline   Reply With Quote
