Old 01-01-2005, 03:15 AM   #1 (permalink)
Default Discovery thermostat
Hi
Can anyone help with some info, I have a 1993 Discovery 2.00 mpi. Do you know the Quinton Hazel part number for the cooling Thermostat, and where its located on the engine, the top hose from the rad seems to go straight into the block via a aloy housing with no obviouse thermostat fitting. ????
500bhp is offline   Reply With Quote
Old 01-01-2005, 08:42 AM   #2 (permalink)
its inside that alloy housing...
rov'n is offline   Reply With Quote
Old 01-01-2005, 09:47 AM   #3 (permalink)
Do you have to remove all the timing belt guard to see where the thermostat is located??????
Old 01-01-2005, 04:47 PM   #4 (permalink)
just follow the top hose, should be 2 bolts holding the thermostat housing on take those out, pull off the housing and there is the thermostat...
