Old 10-28-2005, 10:34 AM   #1 (permalink)
Default Discovery V8 Auto 1998 Reverse Bang/Slap
Help! When i select reverse on my v8 Auto 1998 Discovery it bangs/slaps into reverse. The degree to which this happens varies from wonderfully smooth to quite a disconcerting bang. This does not happen in forward gears.
The car has a full service history and has only done a genuine 56,000miles.
I have had an expert check everything and re-lube using correct oils etc and he was impressed at how well maintained the car is and found no faults after meticulous investigation. He only replaced a couple of minor parts, just in case and to be sure.
Has anyone experienced this? Some say it may even be a characteristic of the model where some are worse than others.
I am grateful for anyones help or similar experiences, Thanks!
Phidge is offline   Reply With Quote
Old 10-28-2005, 11:44 AM   #2 (permalink)
sven's Avatar
Some slop is normal...mines been doing it for 3 years, hasnt gotten worse or better.
Old 10-28-2005, 11:48 AM   #3 (permalink)
Default V8 Reverse Slap/Bang
Thanks Sven, i appreciate your comment.
Old 10-30-2005, 02:31 AM   #4 (permalink)
AZROVER's Avatar
My '98 does it to. I just cross my fingers evertime I shift!
AZROVER is offline   Reply With Quote
Old 10-30-2005, 02:44 AM   #5 (permalink)
Joe Beierly
oberdahill's Avatar
Same thing on my D1. I put it in neutral for a couple of seconds before shifting from Drive to reverse. That tends to alleviate the "hard" shift and banging noise. I don't know if it makes a difference, but it keeps the anxiety in check.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
oberdahill is offline   Reply With Quote
Old 10-30-2005, 03:33 AM   #6 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
Mine's done it as long as I can remember, but I read on here that it's nothing to worry about, and it's never been a problem, so I'm not concerned. Gives the truck character
Felix J. Lockhart
1995 Land Rover Discovery (Series 1)
FelixLockhart is offline   Reply With Quote
Old 11-03-2005, 03:30 PM   #7 (permalink)
Al's Discovery's Avatar
Default Reserve 'Bang Slap'
My 98 has been doing this since day one. Seems to be a characteristic of the selector/box and quite normal. I also found a second in neutral prior to going into reverse will alleviate the worst of it.
Al
Al's Discovery is offline   Reply With Quote
Old 11-03-2005, 04:19 PM   #8 (permalink)
Rocky Mountain High
Funrover's Avatar
It's not supposed to? LOL Mine does it....165,000 miles and hasn't let me down....
Old 11-03-2005, 08:07 PM   #9 (permalink)
Rover Enthusiast
cgaulding's Avatar
Odd, I have a 98 Discovery and mine doesn't do that at all.
cgaulding is offline   Reply With Quote
Old 11-04-2005, 04:38 PM   #10 (permalink)
texasrover's Avatar
I dont recall a time my Disco has ever not "clunked" into reverse. I have close to 160,000 miles.
That is not a leak! That is undercarriage rust inhibitor.
98 Discovery
