Old 06-07-2006, 11:34 PM   #1 (permalink)
Mark HH's Avatar
Default DIY Suspension lift - that old gem!
Hi All,
I'm just about to buy myself a suspension lift kit +2"
Nothing too special just something to spruce up the old bird after 145 000 miles of hard use! So, more than likeley Pro-comp shocks and Bearmach springs.
I want to fit the lift myself - can anyone give me advice? How do I get the old springs out - more importantly - how do I get the new ones in?
I'm quite happy to use my angle grinder to get the old gear off - but what tools will I need to put the new stuff on?
As soon as the lift is on I'm off to Nene Valley in N'hampton to have a set of monster 255/85 BFG muddies put on!!!!!!!!!!!
Cheers!
Mark HH
Mark HH is offline   Reply With Quote
Old 06-08-2006, 05:54 AM   #2 (permalink)
Steve R.'s Avatar
Default 2 inch lift
Check out Discoweb
www.discoweb.org Under the tech section Spring and Shock install. Very thorough. I think you will also need to trim your fenders, if your going to run larger tires. Look under tech, fender trimming for that.
255/85 will rub your radius arms in tight turns.
Land Rover Discovery 1996 with Mods:
Lift (3"), Sliders, Expedition Rack, Winch (Warn xd9000i), Bumper & Brushguard, Lights, Skidplates, BFG Mudders, Ladder, Hi-lift etc.
Steve R. is offline   Reply With Quote
Old 06-08-2006, 07:29 AM   #3 (permalink)
Mark HH's Avatar
Thanks for that - I'll have a look.
I have already chopped the arches off (all the flat vertical bit) when I put 235/85's on without a lift.
I do have the wider offset modular wheels so maybe I might just miss the radius arms - the 255's will only be 10mm wider each side...
Cheers
Mark HH
Old 06-08-2006, 09:45 AM   #4 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
Originally Posted by Mark HH
Hi All,
I'm just about to buy myself a suspension lift kit - 2"
Did you really mean minus (-) 2" or should it be + 2"
The Best 4X4XFar
Old 06-08-2006, 10:15 AM   #5 (permalink)
Mark HH's Avatar
PLUS 2"
It would be weird looking if I lowered it by 2" and then squeezed 33" tyres in there!
Cheers for pointing that out!
Mark HH
