Links
Old 05-02-2008, 09:28 AM   #1 (permalink)
UsedBlue's Avatar
Default Do You Need To Reset Computer After Replacing Spark Plugs?
Does this truck need you to remove batt cables to reset computer when installing new spark plugs on a Disco I 1994?
Dumb question, I know but we'll have to reset radio code and find the code if we disconnect battery!
Thanks for any help you can give
UsedBlue is offline   Reply With Quote
Old 05-02-2008, 10:52 AM   #2 (permalink)
sven's Avatar
no
99 D1
73 Series SWB
95 RRC LWB - Sold
Old 05-02-2008, 11:09 AM   #3 (permalink)
Elemental's Avatar
Heads up.
If you ever have to reset the computer (Clear check engien light) do not disconnect the battery.
In the underhood fuse block, pull the fuse marked "Fuel Injection"
This will not work on 96-up.
fl spark plugs replacement bourouba Freelander / LR2 3 03-17-2008 05:53 PM
Bosch plats. Elemental The Lounge 9 02-13-2007 08:55 AM
Spark plugs imag Discovery Series II 27 11-13-2005 03:27 AM
Replacing Spark Plugs hugodiscoII Discovery Series II 1 08-11-2005 11:48 AM
Best spark plugs for the Range Rover mr.rover Range Rover P38, Mk III and Range Rover Sport 4 10-11-2004 07:43 AM
