Old 09-01-2006, 09:44 PM   #1 (permalink)
Default Don't disconnect battery?
Why is it I find all over the internet warnings about disconnecting the battery in my 96 Disco? May have to change that one out some day!
Rebelman is offline   Reply With Quote
Old 09-02-2006, 05:37 AM   #2 (permalink)
The main reason is because if you have a factory radio and don't have the radio code, you won't be able to use you radio.
Unhooking the battery for too long can errase alot of info from your ECU and then it has to go thru a long relearning curve over the next couple tanks of gas.
Old 09-02-2006, 06:01 AM   #3 (permalink)
So it will not necessarily leave me stranded? Thanks
Old 09-02-2006, 08:58 AM   #4 (permalink)
pavel's Avatar
Rebelman -I have disonnected the battery many times without any trouble other than having to punch in the radio code. If you have two 4 foot wires (black and red is nice) with small alligator clips on each end, you should be able to hook up a new battery while maintaining current flow to the vehicle from the old battery.
Old 09-02-2006, 09:30 AM   #5 (permalink)
Thanks. I thought so. If not for this forum, not sure what dense heads like myself would do?
Old 09-02-2006, 10:02 AM   #6 (permalink)
They make a deal you can plug into the cigaretted lighter that keeps enough current so it doesn't re-set everything when you disconnect the battery, most parts stores have them.
jhmover is offline   Reply With Quote
Old 09-02-2006, 11:11 AM   #7 (permalink)
Thanks. Will look into getting one.
