Old 08-17-2007, 07:19 PM   #1 (permalink)
Default Door lock actuator replacement
The dealership told me that I need a new door lock actuator. The remote will not open the door completely. They want an obscene amount of money to to do this. Approximatey $800. I can purchase the part for $227. How hard is this to do myself? How do you acces the part? Does the side panel come off easily?
jlonigro is offline   Reply With Quote
Old 08-17-2007, 11:08 PM   #2 (permalink)
Disco 1's Avatar
i believe its pretty easy, the inner door just pulls off. it is held on by plugs that snap in. then theres a plastic sheet held on by some kind of sticky black sealant. just peel that out of the way, then you should be able to access it pretty easily. mine is broken too, it was making a machine gun noise when i would lock or unlock the doors. so i just went in there and unplugged the actuator so it only works manually now. i think it should be pretty easy to do it yourself, save that money for something else.
Disco 1 is offline   Reply With Quote
Old 08-18-2007, 06:09 AM   #3 (permalink)
Start over, go to http://www.roverlandparts.com/index....S&Category=296
and buy a used one from the from $50 and up and they are guaranteed used parts that have been tested prior to shipping.
Old 08-18-2007, 05:32 PM   #4 (permalink)
That's awesome. Thanks for the link. I'm just a bit concerned about taking off the panel. Any further details on what and how to do it would much appreciated. Does the speaker need to be removed first? Does it pry off from a certain point? Does reinstall easily? Things of this nature concern me.
Old 08-19-2007, 04:47 PM   #5 (permalink)
pavel's Avatar
jlonigro: Get yourself a Haynes manual!!! Here are the first few steps to gain access to the locking mechanism/actuator.
1 disconnect battery (this will decommission your radio if you don't prepare first)
2 take off armrest (2 screws)
3 remove door lock handle surround (1 screw)
4 lever off the door trim panel all the way around (screwdriver) & lift up
5 undo the speaker wires & remove the door trim panel
6 peel off the plastic seal
You'll probably destroy some of the plastic fasteners that hold the trim panel on - get replacements at an auto parts store, not the dealer. I've never look at the actuator on our '96 D1 but wonder if this site might be useful:<http://www.flashoffroad.com/Maintenance/DoorLock/doorlock.htm>
Visit my j**p website
Old 08-20-2007, 12:54 PM   #6 (permalink)
on, off, on, off, on...
Capt. Ron's Avatar
Take it apart first and make sure it's not the circular spring that's broken. Much cheaper fix than anything.
03 Disco w/CDL
95 Disco
98 Disco: my first (gone)
Capt. Ron is offline   Reply With Quote
Old 09-07-2007, 03:02 PM   #7 (permalink)
Direct bolt in replacement for all but driver's side. $5.
http://www.partsexpress.com/pe/showd...number=330-010
Whole kit including driver's side 5 wire: $40.
http://www.partsexpress.com/pe/showd...number=330-013
Don't waste your money on a used one.
lordkenyon is offline   Reply With Quote
Old 09-07-2007, 05:35 PM   #8 (permalink)
easy fix-did mine in under two hours with used part-use a carpenter flat bar to remove the panel, work your way around slow and comes off easy
russdonna is offline   Reply With Quote
