Links
Old 05-10-2007, 09:20 AM   #1 (permalink)
Default Door locks won't engage all the way
Hey folks... this is a recent problem. Both the back tailgate lock and the left rear door lock won't engage or disengage with the power door lock buttons.
The rear doesn't move at all.. and the passenger back door won't raise quite high enough to unlock it. It does work fine with key in back.
Any clues how to fix?
Thanks!
Wayne from Oregon
IFBwax is offline   Reply With Quote
Old 05-12-2007, 09:04 PM   #2 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Cool
Check the passenger lock switch first. It may be dirty or need some soldering.
Worst case , the body ecu is acting up.
As for the cargo door, you should get the workshop manual or the Haynes manual and attempt to take apart that door. The mechanism may need some silicone or lithium grease and some TLC.You would see it go up partially when you get ice in it. That it would be doing it now suggests you have a new development in the door mechanism.
Good luck.
inert facts.
Old 05-13-2007, 08:14 AM   #3 (permalink)
Thanks Adam.. I'll give it a try.
