Door Panel Removal for D1 - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 12-11-2011, 03:23 PM Thread Starter
CarolinaRover
Quoted: 0 Post(s)
I own a 1997 LR Disco I. The right Rear window regulator is out. Window will not go back up. How do I remove the door panel so I can access the regulator? I felt around the panel for the anchor pins that everyone talks about - but I cannot feel any. I Dont want to just torque off the pannel for fear that I might break something. Any advice on how to remove the panel without breaking it? Much appreciated.
JCSinSC is offline
post #2 of 4 (permalink) Old 12-13-2011, 11:19 AM
Quoted: 2 Post(s)
Buy a panel popper/removal tool from your local auto parts store. Slide it behind the panel anywhere and EASILY pull out. You should be able to see where the plastic panel studs are when doing this because it will not want to pull away from the door fame. Once you get one the others follow easy.
fishEH is offline
post #3 of 4 (permalink) Old 01-01-2012, 05:30 PM Thread Starter
CarolinaRover
Quoted: 0 Post(s)
Thanks for the Info
OK...Got it done!! Thanks so much for the advice. The door panel was the easy part. The motor on the window regulator was only running in one direction (down) and the guide sleeve for the regulator arm was broken (nylon). I took the pragmatic approach and used two wooden dowel rods to place in the window tracks to keep the window up. I removed the regulator and will fix it/replace it later. For now, at least, I have a window that stays up and it not covered in duck-tape to keep the rain out.
Thanks again for the great advice!!
JCSinSC is offline
post #4 of 4 (permalink) Old 01-01-2012, 07:18 PM
Spike555's Avatar
Quoted: 1 Post(s)
How to: Window Regulator Bushing repair - Land Rover Forums - Land Rover Enthusiast Forum
Window Regulator Bushing Repair(alternative method) - Land Rover Forums - Land Rover Enthusiast Forum
2nd owner of a '97 Disco with a ARB winch bumper, SD roof rack, Rover Racks ladder, Cooper S/T's and 220,000 miles on the clock and still a daily driver.
Spike555 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Disco II driver door panel removal mlorraine1 Discovery Series II 3 12-12-2009 06:28 PM
P38 - Door Panel Speaker Surround Removal - How To? Tom Sederburg Range Rover P38, Mk III and Range Rover Sport 3 10-26-2009 07:00 PM
Door Panel Removal Detail sgnden Range Rover Classic 6 02-15-2009 03:46 PM
cargo door panel, drivers door panel jed Discovery Series I 2 02-22-2007 05:59 AM
passenger side door panel removal GentrysRover Discovery Series I 1 02-20-2005 05:19 PM
You may post new threads
You may post replies
