Old 01-30-2005, 11:42 PM   #1 (permalink)
Default dual exhaust?
I'm just curious if anybody has put dual exhast on their disco, and if so what kind of results did you get? was it worth it?
99 disco ii w/ cold climate and SLS.
plastic is offline   Reply With Quote
Old 01-31-2005, 02:19 AM   #2 (permalink)
Super Moderator
Disco's Avatar
I have headers fitted to both my discos but they join into a single exhaust pipe. Unless you have intentions on doing major engine modifications the expense of getting a dual pipe exhaust system made would not be worth the small amount of gain you would achieve. If on the other hand you are not going to do engine mods, then some small gains can be achieved with a set of headers with a single pipe exhaust.
Old 01-31-2005, 03:03 AM   #3 (permalink)
i was thinking just cat-back dual exhaust
Old 01-31-2005, 11:12 AM   #4 (permalink)
I agree, even cat back dual, if it were available woudn't be worth the money with out alot of engine mods. also. Besides it will just be one more thing that will get in the way off the road.
Mike J.
Old 01-31-2005, 03:07 PM   #5 (permalink)
plastic:
I'm working this out as a future summer project,but the only way to go is installing a universal single-to-dual exit muffler with the same measurements as the OE one, and then having them both exit at the driver's side, just as the early range rovers,as you will have clearance issues on the passenger side,besides that if you modify the cat setting,you will have issues with a continuous service engine light(there are 4 O2 sensors,so the thing is pretty sensitive...).
Carlos
Carlos is offline   Reply With Quote
Old 01-31-2005, 03:15 PM   #6 (permalink)
drewclare25's Avatar
what about flowmasters....come as dual pipes for 300 where i am
drewclare25 is offline   Reply With Quote
Old 01-31-2005, 03:30 PM   #7 (permalink)
I also know BORLA makes a good aftermarket one,no dual though.
Carlos
