E-Brake Handel
Ok, this may sound simple, but I wouldn't be here if I wasn't thoroughly confused. So I have 2 1995 Discovery 1's, and they both have the exact same problem. When I first got them, the e-brake handle worked fine. But I removed the center console to gain access to the transmission tunnel, and had to remove the e-brake cable. No big deal. When I went and put the center console back together, the e-brake would not lock into place. I made sure that the teeth were making contact with the locking mechanism, and sure enough it is. You push on it, and you can get it to lock, but once you push the button, it seems to jam into place, and won't release to re-lock. I thought it was just a bad handle on the first one, but the second time makes no sense to me. I do need a e-brake on that one because it's a 5 speed. I've searched the internet to no prevail, so any help would be appreciated. I know my descriptions are very helpful and all, so I'll try to get some pics, or a video up tomorrow to try and explain what the heck is going on.
