Old 01-10-2006, 03:21 PM   #1 (permalink)
JamesVee's Avatar
Default ECM Module:
Where is the ECM Module located so I can hook up a code reader to figure out why this check engine light is on?
Check out my websites: Family Trophies and Africa Pictures
JamesVee is offline   Reply With Quote
Old 01-10-2006, 04:23 PM   #2 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Arrow
Hi from Adam in NYC
It does not quite work that way.
The ECU had several designs including an OBD 1 prior to 95 and then 96 - on a OBD 2. It helps to know which model you have.
Prior-95 : You need a special display hidden in the passenger seat.
96-on: You have to look at the kick panel for the drivers position. You will see a data plug in which you will need a OBD2 code reader.
Get a fully-featured one or better yet get a CarChip F/X . That will do two functions. One is that you can log your vehicle performance. Second is that it will double as a codereader using a personal computer or laptop.
You can also reset your check engine light with the CarChip F/X. You can get it for cheaper thru eBay.
http://cgi.ebay.com/ebaymotors/DRIVE...WDVWQQtcZphoto
Adam in NYC
PS If you have a 96-on D1, the ECU is next to the antenna beside a vinyl box in the engine compartment.
Old 01-10-2006, 05:02 PM   #3 (permalink)
JamesVee's Avatar
I've got a '99 DSI, SD series.
