Old 07-27-2006, 06:31 PM   #1 (permalink)
appstatedisco's Avatar
Default ECU repair
can someone post some pictures of their window ECU and what a bad connection might look like? I might be going in for repair in a day or two, just seeing if anyone had some pictures on hand.
AHO Rugby, a drinking club with a rugby problem.
www.ahorugby.net
"My experience through life has convinced me that, while moderation and temperance in all things are commendable and beneficial, abstinence from spirituous liquors is the best safeguard of morals and health."
- Robert E. Lee
appstatedisco is offline   Reply With Quote
Old 07-28-2006, 06:24 AM   #2 (permalink)
If it has failed, you have nothing to loose, pull it out and open it up, look fro loose solder joints, cracks and burn or hot areas. Once you find whats wrong, if you can fix it great, if not buy a new one on line, it will be alot less expense and a learning experience.
Old 07-30-2006, 01:34 PM   #3 (permalink)
Just fixed mine this past week and it work perfect. It's a real pain to get out and I couldn't get the circut board back in perfect, but it works great and saved me a couple hundred, at least. Here is a link explaining http://www.discoweb.org/, click on "tech" and then rear electric window. Good luck.
vnsherry is offline   Reply With Quote
Old 07-30-2006, 07:28 PM   #4 (permalink)
Thank you so much for that link. The step by step with the pictures is great! Much appreciated!
www.ahorugby.net
- Robert E. Lee
Old 07-31-2006, 09:42 AM   #5 (permalink)
Default No problem
That's funny, I didn't even realize you were up in Boone. I just moved back to Charlotte from Boone about 8 months ago. I was up there running for ZAP Fitness for about a year... Small world. On a side note my 97 discovery is even the same color as yours. Good luck with the repair.
