Old 04-25-2006, 07:12 PM   #1 (permalink)
the big yellow one is the sun!
VArova87's Avatar
Exclamation electrical blues
tach hasnt worked for about 2 weeks, but my alt. is still charging so i didnt worry about it. tonight, while sitting in a parking lot during a thunderstorm (traffic was heavy, wasnt moving) my radio cuts out, lights dim, and my airbag and anit-lock brake lights come on. they come on and off, mostly on, while driving home. my interior lights go dim, and speedo drops every time i hit the brake. in other words, im driving on a dead battery. get home, cut off the engine, disconnect the batt for a few mins. hook it back up, car BARELY starts. check the volts on the batt, its perfect. 10 mins later, batt is still perfect and the alt is back to charging. my question: what in the WORLD is this foreign car doing? its got a mind of its own! anyways, is it possible for your alt to charge but your tach not to read it? is there some sort of gear running the tach that could go? also, any suggestions on how to mend this electrical system? thanks for the help.
97 D1
3" OME
32x11.50 BFG ATs
GCR steels
headers, exhaust, etc...
VArova87 is offline   Reply With Quote
Old 04-25-2006, 07:21 PM   #2 (permalink)
MG
me.guevara's Avatar
Those were the very simptoms that I had when my alt started to go - it was an intermittent failure that became progressvely less intermittent. Sounds like you were running exclusively off the battery: the alt wasn't producing any energy or the energy it was producing wasn't making into the proper bus.
You should check all the electrical connections (clean, reseat), especially those to/from the battery and alt, check your fuses, and for peace of mind, have the alt checked at Autozone (or something like that - I understand some places do it for free).
If it is the alt, go for a Mean Green HD replacement...
Good luck!
________________________
MG
'95 Disco I, 3.9L V8i 5-speed
Discoverying Bolivia...
Old 04-25-2006, 08:32 PM   #3 (permalink)
Otherwise known as STEVE
Classic alternator death syndrome. I can't second the mean green suggestion, as I've heard mostly negative about them.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 04-25-2006, 09:31 PM   #4 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
I had similar symptoms in my '95. Check the belt to make sure it's routed properly and that the tensioner is working. Also, make sure the battery is still holding a charge correctly. And, of course, have the alternator checked, or just replace it. You can get one at Advance for half the price of a factory one, or go for a Mean Green alt
Felix J. Lockhart
1995 Land Rover Discovery (Series 1)
FelixLockhart is offline   Reply With Quote
Old 04-26-2006, 06:37 AM   #5 (permalink)
Sounds like the alternator for sure. When you checked your battery, how did you do it and what was the voltage?
Old 04-29-2006, 08:52 AM   #6 (permalink)
VArova87's Avatar
towed it to my local shop, turns out my alt was out completely. replaced it and its working fine, but my tach isnt working at all now (it wasnt before the alt went either). so a friend of mine has a brother that works at the LR dealer in knoxville. he is going to come up here in a few days and check her out. thanks for the help!
97 D1
3" OME
32x11.50 BFG ATs
GCR steels
Old 04-29-2006, 04:51 PM   #7 (permalink)
VArova87's Avatar
ok guys, i NEED HELP! that new alt. is now not charging, batt is dead and when charged, it will keep the car running for about 20 mins then is dead again...its a brand new alt, so would a bad battery cause this? also, are there any other kind of electrical problems i should check for? ps, my tach still isnt working...what in the world could it be that keeps killing these alternators?
97 D1
3" OME
32x11.50 BFG ATs
GCR steels
Old 04-30-2006, 04:32 AM   #8 (permalink)
nzoliver's Avatar
Gallery: 5
I would be looking at a new battery. Sound like the old 1 is going short circuit. Kills alternators dead.
My 2c worth.
nzoliver is offline   Reply With Quote
