Old 04-26-2006, 07:20 PM   #1 (permalink)
boogiedown27's Avatar
Default Electrical problem
Hay fellas on my 95 disco I have another problem that surfaced it's ugly head. When ever I turn my lights on my dash lights go out, and the outside parking lights and rear lights cut off. I got pulled over also too lol... I called myself checking the fuse and it was fine, if it was the right one? ANY insights guys?
Thanks
boogiedown27 is offline   Reply With Quote
Old 04-26-2006, 08:52 PM   #2 (permalink)
Bogatyr's Avatar
Default grounds...
boogiedown27,
As these discos start aging, they'll face the problems that older rovers faced, but the electrical bits are harder to get to.
So, if your parking lamps are on, your dash lamps are on as well? Ick, as a start, poke around to whereever you see a ground wire, disconnect, clean and reattach. Time consuming, but cheap and easy...Guess it could be the switch too, but before throwing parts at it, check the basics...
Bogatyr
Current Rover Fleet:
Old 04-27-2006, 04:20 PM   #3 (permalink)
Default Main Lighting Switch
Take the cowl off of your steering column and check the connections on the switch on bottom left. There are two. One is the main lighting switch and the headlights, tail lights, and side lights circuits are through it. It could just be loose. If you want a photo, email me at wade@corridor.net. It was too large to attach.
Wade
wade is offline   Reply With Quote
Old 04-27-2006, 11:33 PM   #4 (permalink)
Thanks..I found out today it's the switch!! I tried cutting on my bright lights and the light switch won't stay in place for the brights to stay on, and when I would hold the switch then my parking lights would come on?? But when I let it go the parking lights would cut off and just the head lights would be on..
Old 04-27-2006, 11:46 PM   #5 (permalink)
Rocky Mountain High
Funrover's Avatar
See if PPR has some used ones for you!!
Old 04-28-2006, 12:07 AM   #6 (permalink)
thanks
Old 04-28-2006, 12:09 AM   #7 (permalink)
Rocky Mountain High
Funrover's Avatar
thanks
Yup..... They were tearing down some D1's awhile back....I am sure they have one!!!
Old 04-28-2006, 12:10 AM   #8 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
i had a problem with my switch. at first my parking lights wouldnt turn on then the whole switch assembly melted. it smelled really bad..... got a new switch from british pacific and problem was fixed. the new switch also moves super smooth! if you find a d2 headlight switch, itll work on your d1.
Arsell
My Car Domain Site
llesra is offline   Reply With Quote
Old 04-29-2006, 09:09 AM   #9 (permalink)
thanks guys,
I appreciate it!
