Old 07-11-2006, 11:34 AM   #1 (permalink)
LRDisco94's Avatar
Default Engine Cut Off?
Hey guys... been gone for two months...up in maine for the summer..managed to find local internet access.... My mother decided tht she would drive the Rover ..on the way back she said it started to over heat..she turned the heat on full blast but did not pull over which kinda upset me..anyways she was only like 2 miles from home...she made it to the entrance of the driveway where it shut off..... my question...is the computer programed to shut off if it gets to hot or did something fry...
O the bottom hose from the radiator busted to bits.... sooo all the fluid leaked out
-LRDisco94-
www.floridalandroverclub.com
LRDisco94 is offline   Reply With Quote
Old 07-11-2006, 11:42 AM   #2 (permalink)
NO!, You have problems, can't say what, but the computer didn't shut you down.
Need to look at the engine for possible overheat damage.
Old 07-11-2006, 05:51 PM   #3 (permalink)
RageRover's Avatar
x2, yeah all that overheat can cause the metals in the engine to warp, and move in ways it was not meant to be.
Does the motor still start and run after that shut off?
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 07-12-2006, 12:50 PM   #4 (permalink)
LRDisco94's Avatar
dang, i cant tell about the motort, im still up here in maine...my dad said he went out and filled it up with water and it started and drove up the driveway and tht was it.. he ordered the new hose, i havent talked about it since then...... tht was what i was afraid of WARPAGE, i was like (trying not to yell) why didnt you pull over? she said she was right down the road from the house and she turned the heat on... but i was thinking tht even driving for 2 miles with the temp gauge on H tht cant be good... man i just hope nothin wrong if there is im gonna scream.... cause we just got done rebuilding the heads and replaced the timing gear/chain ..... i should of drove up here....
-LRDisco94-
Old 07-12-2006, 12:56 PM   #5 (permalink)
smileyq's Avatar
Sorry man Best of luck with it. Keep us up to date as to what is going on with it.
"Good saddles ain't cheap, and cheap saddles ain't good."
smileyq is offline   Reply With Quote
Old 07-12-2006, 01:14 PM   #6 (permalink)
When you get a chance, have a shop do one or both coolants tests to see if there is a problem, both chemical and sniffer if needed.
If it is OK, then make sure there is no air left trapped in the engine and do any engine flush to help det rid of any excess sludge and burned oil.
Good luck,
Old 07-12-2006, 02:12 PM   #7 (permalink)
96owner's Avatar
just a question why did she turn up the heat
96owner is offline   Reply With Quote
Old 07-12-2006, 02:41 PM   #8 (permalink)
Otherwise known as STEVE
It's a way to reduce the water temp in the engine- using the heater core like a little mini-radiator.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 07-14-2006, 11:09 AM   #9 (permalink)
AFIROVER
afirover's Avatar
only works if thier is water
afirover is offline   Reply With Quote
Old 07-17-2006, 12:25 PM   #10 (permalink)
LRDisco94's Avatar
Well it started and ran fine my dad said.. he ordered a hose set from AB... but i will mention the tests and the engine flush... Thxs for the info guys
-LRDisco94-
Old 07-17-2006, 03:32 PM   #11 (permalink)
RageRover's Avatar
Cool beans man! Glad to see that motor still runs.
I bet it had to be a relief to hear it run fine.
1995 RRC LWB
