Old 12-03-2007, 06:51 AM   #1 (permalink)
jed
jed's Avatar
Default Engine/diagnostic trouble
Ok now this all started with the check engine light coming on,I went to a local
foreign auto shop they found a code for a o2 sensor (bank 1 sensor 1) they
drove it apparently to reset the light there's a note from the tech says
code pending in computer P1178 well I got it back drove home (10miles)
no problems that was friday today I go to start it battery's flat well thats a bitch never happened before battery's 3-4 years old O well check the alternator
output it's 14V little higher then I'd like but it's charging so I head out and it seems ok at first but when I go to stop it wont idle the tech reads 1500rpm and
by the sound it's right so I figure maybe it's trying to charge the battery?
well I get to where I'm going 15 min drive and when I park same thing wont idle
I check the pedal it's up all the way and after 1 min it idles 700rpm-ish so I tap
the gas pedal it shoots up to 2000rpm bounces around 1500rpm for 10-20 secs
and returns to 700rpm I repeat it a few times it does same thing every time so
now I want to try and figure out what can/might cause this any advice would help tremendously.
96 Discovery SE
72 M35A2
I'd rather push my landy then drive a cruiser!
jed is offline   Reply With Quote
Ignition Key Trouble discofacelift Discovery Series II 1 08-12-2007 03:56 PM
offroading trouble ryanc8514 Range Rover Classic 13 03-31-2006 02:58 PM
Trouble starting... oceanswithin Discovery Series I 1 10-05-2005 08:44 PM
Landrovers financial trouble craigrmartin@silofx.com General Land Rover Discussion 4 04-16-2005 10:23 PM
SOS 98 SI Disco Gear Trouble PHOENIX Discovery Series I 3 11-01-2004 05:32 AM
