Old 11-06-2005, 12:47 PM   #1 (permalink)
Default Engine dying out when driving
Hi all.got one problem sorted and another one happens.My 1995 disco 1 v8i 3.9 lpg has started to die when driven.Everything just dies as if you switch the ignition off then most of the time she restarts then dies again 100 yards down the road then starts then dies.Anybody got any ideas or should i scrap it now.getting a bit p***ed off with it now
dizzy is offline   Reply With Quote
Old 11-06-2005, 01:00 PM   #2 (permalink)
tomkat's Avatar
Default Coil?
I would pick up a coil and replace this item, when they heat up they will kill the voltage to the distributer, and shut down the engine. this is a quick easy cost effective try. When it dies does it sputter or just cut out?
It is easier when they die and stay dead to trace the electirical with a muti-meter looking for power and no power. I would start with the coil you will just need to pull the old one and insure that is either has a internal resister or non internal resister and replace.
tomkat is offline   Reply With Quote
Old 11-06-2005, 04:50 PM   #3 (permalink)
Default Engine Dies
When it dies, how easy is it to restart? One of Rovers other problems is the fuel pump and or filter.
You are going to need to do a little more checking before you find this one, and it shouldn't be a major fix.
Mike J.
Old 11-07-2005, 11:41 AM   #4 (permalink)
Hi.Most of the time she will restart straight away.but last night the battery almost went flat but it did start eventually.All the internal lights/headlights/dashlights stay on as normal!.It is as if you have swichted the ignition off it dies that cleanly.no spluttering/shuddering/loss of power????
Old 11-08-2005, 01:43 AM   #5 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
Holy crap, I just did this in my Disco, and the difference is amazing! It's always sounded kinda weak, and sporadically kills out at random. So, I stuck a Bosch coil from a VW Rabbit (spare parts from my mate's project car) to test, and it's like someone replaced my engine with something from NASCAR. Thanks for the tip, tomkat! I've got an MSD high-vibration coil on the way (epoxy based instead of oil-filled, prevents the wire wraps from shaking loose), I'll have to post some pics of it
Felix J. Lockhart
1995 Land Rover Discovery (Series 1)
FelixLockhart is offline   Reply With Quote
Old 11-16-2005, 01:03 PM   #6 (permalink)
Default disco still dying
Just fitted new coil to car and its still dying.Got the RAC man out and he thinks it could be the rotar arm???? Is this possible?????.Its in the garage at the moment and being test driven and its not dying so how can he fix it if its not doing what it has been doing(8 times in 3 miles) .I think i will have a screaming fit very shortly if somethings not sorted out.Then im seriuosly gonna think of selling/scraping it
Old 11-20-2005, 08:30 PM   #7 (permalink)
Some common problems I have seen is the fuel pump, the fuel pump harness (connecters at both ends), The vehicle speed sensor mounted on the T-box,
Ignition module and ignition pickup in the distributor. As far as checking. Your technician should hook up a fuel pressure gauge and monitor the pressure while driving. The technician could also hook up a spark tester to monitor spark while driving. A volt meter can be used to check the speed sensor but a good indicator is the speedometer cutting out when the condition occurs.
TRAILCHARGER is offline   Reply With Quote
Old 11-21-2005, 09:25 PM   #8 (permalink)
RoverChic's Avatar
VSS - Especially after what you have described.
2006 Range Rover Sport HSE Rimini Red
2001 D2 CDL
1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired)
1988 RRC SWB ('Silver Bullet' Retired 05/98)
RoverChic is offline   Reply With Quote
Old 12-20-2005, 12:39 PM   #9 (permalink)
Well hello all.Well the problem has been solved now.It was the distributer(sp).the whole thing has gone.so we made the awfull discision to get rid of it.So its now gone and in its place is a Landrover Defender.To be honest the disco was a complete dog from day one.And i for one am glad to see the back of it.It was one thing after another.We could of spent thousands on it and it probaly still would of broke down.But thank you all for your help and advice to try and help us save her!!.
