Engine stays on after ignition is off. - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 10 (permalink) Old 08-12-2005, 01:40 PM Thread Starter
Quoted: 0 Post(s)
Just started happening, I turn the key to the off poistion so the engine turns off but it doesnt.. After a minute then it turns off. I have no idea what might be causing this
-Militant Grunt
Militant-Grunt is offline
post #2 of 10 (permalink) Old 08-13-2005, 07:59 PM Thread Starter
Quoted: 0 Post(s)
Any ideas guys? First it was a minute now the time it takes to shut off is getting longer and longer.. I have no clue... Earlier in the week I had a mechanic do some electrical work on the rear windows, he "bypassed something to give the rear windows power." could this be associated with the ignition?
-Militant Grunt
post #3 of 10 (permalink) Old 08-14-2005, 03:49 AM
Disco's Avatar
Quoted: 0 Post(s)
Check your idle speed isn't too high.
Disco is offline
post #4 of 10 (permalink) Old 08-14-2005, 11:04 AM
Quoted: 0 Post(s)
Is it dieseling or still running? Maybe you should test to see if the ignition is still firing when you turn the key off. Hook up a timing light and see if it still flashes or something. What's causing it to shutdown? Do you think the engine is still running until the fuel pressure subsides?
O.B. is offline
post #5 of 10 (permalink) Old 08-14-2005, 08:23 PM
Black Magic's Avatar
Quoted: 0 Post(s)
Hopefully its not injectors staying open!!
That can put your engine up to the red line with no way of shutting it off in an auto - at least in a manual you can pop the clutch in 5th with the brakes on and stall the engine.
Black '02 Discover SII, Auto.
Black '87 Suzuki Samurai, rock crawler
Black '94 Discovery SI V8i, 5 spd (Parked. Won't start- Probably a bad ground, alarm gremlins)
--## If you have enough time to do something over again, you had enough time to do it right the first time. ##--
Black Magic is offline
post #6 of 10 (permalink) Old 08-15-2005, 01:54 AM Thread Starter
Quoted: 0 Post(s)
Its just normal idle and after a few mins the engine just shuts off.. Another thing I notice is that the engine shuts off when I close the driver door 0_o This problem is getting weirder and weirder..
-Militant Grunt
post #7 of 10 (permalink) Old 08-18-2005, 08:16 AM
downunderdisco's Avatar
Quoted: 0 Post(s)
Have had it occur on a bike was given the reason that the carbon build up was becoming red hot and even though the electrical system was turned off this was enough to ignite the fuel being drawn through as the pistons kept firing. This was with carbies so don't no if it would occur with injectors, may be if as Black magic suggests injectors staying open.
downunderdisco is offline
post #8 of 10 (permalink) Old 08-25-2005, 11:16 PM Thread Starter
Quoted: 0 Post(s)
I ran a fuel injector cleaner on her about a month ago..
-Militant Grunt
post #9 of 10 (permalink) Old 08-26-2005, 06:30 AM
sven's Avatar
Quoted: 0 Post(s)
I would have that mechanic undo what he did to "fix" your rear windows. There is a delay feature where if you shut off the truck, you still have time to operate accessories like the windows. I bet he somehow wired the ignition accidently to do the same. Opening and closing the door deactivates the delay feature. So thats probably why it the engine shuts off
BTW, your rear window problem can be fixed by either replacing the window lift ECU under the glove box. Or you could resolder the faulty joints : http://discoweb.org/window/index.htm
Good luck
sven is offline
post #10 of 10 (permalink) Old 09-03-2005, 10:44 PM Thread Starter
Quoted: 0 Post(s)
Good luck
You Rock.
-Militant Grunt
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
