Old 01-03-2007, 10:25 AM   #16 (permalink)
I have heard a few people say they have used it and they seemed pleased, I have not used it cause I learned years ago to do the ATF and have had a couple of opportunitys to see an engine opened up after flushing with ATF, does a great job.
Old 01-03-2007, 10:35 AM   #17 (permalink)
daway's Avatar
thanks, might have to try this (ATF). so add 6 qts after u drain the oil then run the engine for 20min w/out driving it. do u have to do anything else after draining the ATF out, before adding a new oil and filter? also about seafoam in the gas tank. do u add that every oil change or every other oil change? would that take place of the lucas fuel injector cleaner that i use every oil change? thanks again
2001 X5 3.0i "dodi"
1993 RRC, county LWB "bertha"
myroverworld
Old 01-03-2007, 12:54 PM   #18 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
SeaFoam is a pretty good cleaner for maintaining the crank case, but if you really want to cleane it go for 6 qts of ATF and a good 20 minute idle, which makes a hugh difference.
Good luck,
I have dumped a bit of oil and run 1 quart of ATF through the engine before an oil change before, filling the entire motor scares me though. I know a guy at work who grandfather is a mechanic from way back, this guy says that everytime his grandfather does an oil change he substitutes 1 quart of oil for 1 quart of ATF and leaves it for the entire 3000 miles! Haven't tried that yet.
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Old 01-03-2007, 01:10 PM   #19 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Originally Posted by Muddy Oval
Mix it with some grapefruit juice and vodka...
Never tried it with vodka........whiskey and coke on the other hand.........
1997 Disco 1
2000 Disco 2
www.mvlrs.com
ON WISCONSIN
