Old 06-29-2005, 11:39 PM   #1 (permalink)
ilovemydisco's Avatar
Default Engine whining/high pitched airy sound
Hey all, I've been noticing that on my D1, in the past week or so, whenever I've got my foot on the gas, no matter how hard or soft, I get a sort of higher pitched whining that sounds like it's coming from the fan belt or drive belt, whatever, you know what I mean, the one that generally does the ticking at idle.
At first I thought it was because I had the AC on, but it doesn't seem to be better or less when it's off. This could just be psychological but I also feel like I have a little less power with this noise.
Anyone have any ideas?? Thanks.
~Erica~
ilovemydisco is offline   Reply With Quote
Old 06-30-2005, 03:13 AM   #2 (permalink)
TerryS's Avatar
Two things to check. Your power steering pump will make a whining noise if it's low on fluid, though if this is the source, you should have noticed it in the resistance to turning the wheel.
The other thing which can cause this whining noise is you belt tensioner pulley bearing. They go bad, but aren't real expensive to replace.
Old 06-30-2005, 12:39 PM   #3 (permalink)
Hm... that belt tensioner thing sounds like a possibility. Do you think that's something my fiance, who is pretty good with mechanical things, could check? I will soon be going into the LR dealership to have a door latch replaced, but don't really want them messing around under the hood - that could cost a fortune! Otherwise, whereabouts is this? I know where the belt is, is this tensioner deep in the engine or right on top? Pictures perhaps or a website that shows this? Thank you for the help!
~Erica~
Old 07-06-2005, 06:49 AM   #4 (permalink)
texasrover's Avatar
That should be right up near the top. Remove the cover to the fan and you should be able to see it. Your fiance should have no problems replacing this... no liquids to mess with... just some nuts and bolts to replace.
Good luck!
Old 07-06-2005, 06:53 AM   #5 (permalink)
01001010's Avatar
Gallery: 15
Erica, did you get the Manual??? Sent it on Friday
JC...
Old 07-06-2005, 08:06 AM   #6 (permalink)
Yep, I got it!! I spent like 45 minutes with the accessories one, wanting each and every one that I don't have!! Thank you so much for sending it to me. It sure arrived fast!
~Erica~
Old 07-06-2005, 08:09 AM   #7 (permalink)
01001010's Avatar
Gallery: 15
WOO!...You saw that thing!...Its amazing!! Gotta love USPS
JC...
Old 07-06-2005, 10:38 AM   #8 (permalink)
rmuller's Avatar
could also be your driveshafts, when the U-Joints start going you'll hear a whining noise while accelerating (generally worse/more noticable in the first gear or two)
Old 08-02-2005, 07:23 AM   #9 (permalink)
downunderdisco's Avatar
Default whining noise
Have just covered 9600 klms in the last 21 days from 1 side of Australia to the other and back have also found I have a whining noise was told by a dealer that it was the alternator on the way out. Had to take the car into a dealer after the car was running super rich never get your car serviced the day before you leave on a big trip cost me a fortune in extra fuel.
downunderdisco is offline   Reply With Quote
