Howdy kind folks,
I noticed the check engine and SRS lights on in my 96 Disco, so I stopped by an Autozone place and had the codes pulled. The following are the codes the ObdII scanner gave: P1193 - ?????? P0158 - O2 Sensor Circuit High Voltage (Bank 2 Sensor 2) P0441 - Evaporative Emission Control System Incorrect Purge Flow I got the code meaning from http://www.obdii.com/codes.html Any ideas as to what these are and what needs to be done to fix them? Please I am not mechanically inclined, so help break it down for this novice. I just recently did an oil change, tune-up and had the fuel filter changed because the Disco was stalling and took too long to start............ a problem that is still occurring. Thanks! |
Rocky Mountain High
![]() Join Date: Sep 2005
po158 is the O2 sensor passenger side after that catalytic converter.
The purge problem I would suspect you have a vacuum leak in the system..or it is plugged, if you have hold of a fog machine use that or just follow the vacuum lines to see if they leak at all... P1193 i have no clue..... |
