the big yellow one is the sun!
ive read as many posts as possible, but being new at this, i gotta ask...
props of a new job - i get any and all parts at cost. in light of this, im ordering lift springs asap. i want to go with 3"...if my 97 has U-joints already, can i make it without a new driveshaft? how long will my stock one last before i need to go replacing it, and how much are they? thanks for the help!
97 D1 3" OME 32x11.50 BFG ATs GCR steels headers, exhaust, etc... |
On a D1. it is a roll of the dice when you get close to 3"s, I have heard many people say they are OK and some who said they had to replace the drive shafts with ones using double cardon shafts.
Who's lift are you going to use? Mike |
i got all my stuff from dap for my three incher and have haven't had a problem yet ***knock on wood*****
Best 4x4xFar 97 Green D1 3" BB springs pro comp es9000 shocks 32x11.50 BFG Mud Terrains 15" american racing steel wheels flowmaster 40 series dual pipes mantec snorkel |
Rocky Mountain High
![]() Join Date: Sep 2005
I am with mike.. I have seen the 3" work great with stock set-up.... Here is what I believe you need to do a 3" right
NEW: Trailing arms radius arms extended brake lines correct shocks etc..... Driveshafts(if a vibration is created) |
Mike,
i was going to go with OME since i can get them at cost thru my business. im prob gonna stick with 2", it looks like too much trouble just for an extra inch. bilstein shocks will go on with extended brake lines. im also looking for a bumper setup for the front so i can add extra lighting and get rid of that dang airdam.
I would suggest your use the 751 front coil especially if you arew going to run a front bumper. You won't need to replace the brake lines for the lift, would be a good idea if your rubber lines are starting though, it will give you a firmer brake pedal.
Mike |
The Best 4X4XFar
It's not lthe lift but the droop that's usually an issue with the brake lines.
Personally I think a 2" lift will work pretty well for most occasions, rock crawling is a bit of a dark art and I'm not the correct person to advise for such a setup. But regardless for a 2" lift I'd go for the correct shocks and springs with cranked trailing arms and 3 degree castor correct front radius arms and longer brake lines. If you wanted another inch of lift you could buy new rear shock mount droppers and heavy duty 1" shorter front turrets.
Land Rover Discovery (3 Door) 200Tdi 5-speed ![]() Mods:Allisport LARGE FMIC | Allisport Tuned | Simex Jungle Trekker II 33.11.50R15 Tyres | 15x8 8 Spokes | Heavy Duty Uprated Suspension (shocks & springs) | Wheel arch Flares | 1" Wheel Spacers | Custom Straight Thru Exhaust | Custom Trimmed Front bumper with twin NATO Hooks | Custom Rear Bumper with single Large NATO Hook 360˚ Swival | Front Light Guards | Custom Aluminium Rear Floor | Bonnet Straps | 100w Spot Lights | Upgraded Headlights The Best 4X4XFar |
new plan...after talking with steve, ill be ordering the 3" BB springs within a week. new, longer shocks will go on as well as extended brake lines. as the money comes in, new radius arms, trailing arms, etc. 33x10.50 BFG ATs have been ordered, as have new wheels from GCR.
#10 (permalink) |
minor trimming will be needed i think. they arent very wide, and ill have .5" spacers on. ill get pics up in a few weeks when its done.
#11 (permalink) | |
Where is my Black Son?
Good luck ont he project, and make sure to take pics!
1996 Disco 1 SE7- Stock(Awesome sound system) DD/Range Rover hauler. 1990 RRC SWB Camel Trophy Inspired- ARB, Hella's, Bosch's, AR's 15X8, 32"MTR's,Equipe suspension stuff, Skids, waiting for more...
#12 (permalink) |
let me know if you need any help man good luck
#13 (permalink) | |
Rocky Mountain High
Pics will be taken.. But it will be awhile!!! ![]() |
#14 (permalink) |
ill take plenty of pics. i ordered the wheels from GCR today. tires will be here soon, and the 3" Big blues and longer shocks will be on the week after thanksgiving. is it remotely possible to find used trailing arms or radius arms that are modified? say if someone went from lifted back to stock? $600 is alot of cash for a college student.
#15 (permalink) | |
Rocky Mountain High
I am with you there.. I am doing the USED shopping list!!! Here is a set for ya! http://www.discoweb.org/forums/showthread.php?t=28103 |
