Old 08-06-2007, 11:03 AM   #1 (permalink)
Default Fan Clutch Assembly
Hi all i have a 94 Disco 3.9 and the fan broke off. I was told i need a fan clutch assembly, water pump pulley. But the fan blade broke too need new fan? Any help on where i can get these parts used or remanufactured? Money is tight. Also, should any mechanic shop be able to do this type of work? thanks
Ruminator is offline   Reply With Quote
Old 08-07-2007, 04:08 AM   #2 (permalink)
of course you do, no difernet then a prop on a boat.
you sure it didnt take out the radiator at all.
Old 08-07-2007, 06:18 AM   #3 (permalink)
Steven Ratajczyk
stevenr's Avatar
If just a fan blade is broken, then all you need is a fan. Do check to see if the blade did any damge to the radiator like Rovin4life mentioned.
Call Will:
http://www.roverguy.com/
He'll take care of you for parts on the cheap. Good luck!
Steven Ratajczyk
'99 Disco 1 with stripes
stevenr is offline   Reply With Quote
Old 08-07-2007, 08:00 AM   #4 (permalink)
What exactly is broken and what is still serviceable? The reason I ask is if the water pump ,shaft and pulley are in good working order you could just ditch the stock fan and clutch assy and replace it with a electric fan and thermostat. Any repair shop worth its salt should be able to handle this kind of work.
"Your only supposed to blow the BLOODY DOORS OFF" The Italian job 1969.
roverandom is offline   Reply With Quote
Old 08-07-2007, 12:47 PM   #5 (permalink)
Default Thanks for your responses. This is what I was told by the mechanic...
the water pump shaft broke the fan ony grazed the radiator ( I did stop as soon as i lost power steering I looked at the temp at that time and it did not overheat.) So he says it needs a water pump and pulley, serpentine belt and possibly a fan clutch assembly they wont know this until they put it back together. Is that true?
Old 08-11-2007, 07:01 AM   #6 (permalink)
Sounds about right.
tempestv8 is offline   Reply With Quote
