When i switch my fan on to heat or anything other than a/c the fuse blows, can't work out why it runs fine on a/c but not on anything else.
They may not necessarily be related but check the following:
F6 25amp Blower – Rear (A/C only) F7 30amp Blower – Front F31 10amp ATC / Blower - Fresh recirculated air motor (Non A/C) On vehicles with rear air conditioning fitted, a 40 Amp in-line fuse is located behind the LH rear quarter trim panel, taped to the harness. The in-line fuse protects the resistor pack used for rear blower motor speed operation. Failure of the fuse will prevent blower operation in speeds 1, 2 and 3. The fastest speed 4 will still operate when the fuse has failed. If your fuses are the correct amps and in good condition then you will have to trace the fault back from the fuse that has blown. It could be a mechanical condition such as a fan is stalling due to an obstruction or failed bearing etc. Or it could be an electrical fault such as a fan motor windings earthing out. ![]() |
Thanks for the help,no a/c at rear, fuse is correct amp and in good condition,fan works perfectly with the a/c on, when you switch to anything else on the 'air supply selector switch' the fan doesn,t opperate and after about 5-10 sec the fuse blows.
