Old 03-21-2008, 06:46 AM   #1 (permalink)
Default Fan Removal
Ok guys, I searched and cannot find exactly what I am looking for.
On a 96 Disco, when removing the viscous fan, I have a wrench on the nut facing upwards, do you hit the wrench towards the drivers or passenger side? Lefty loosey, righty tighty, whatever. Hit it left, or hit it right? I cannot get this fan to crack loose.
asmcmillin is offline   Reply With Quote
Old 03-21-2008, 07:51 AM   #2 (permalink)
antichrist's Avatar
I'm pretty sure it's righty loosey, lefty tighty. In other words, left hand threads.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 03-22-2008, 11:31 AM   #3 (permalink)
Oil Field Trash
ensignderrickman's Avatar
Gallery: 4
yes, I would say the same thing, becase it spins like it does the threads should be left handed.
95 Disco (flipper) Roof rack w/ twin jerry can holders-Deer Killer-Infinity audio system w/sub Already rolled it onto it's side Currently waiting on back ordered RTE parts for a 3 inch lift, 2 inch body lift.
ensignderrickman is offline   Reply With Quote
Old 03-26-2008, 11:55 AM   #4 (permalink)
Carehta's Avatar
No way! I'm about to move the wrench too! Not to challenge the other folks, but the workshop manual says to loose the gas GEMS you hit counterclockwise (right hand) and the diesel is left handed to loose, not the other way around. Tell me which side you moved, bud.
Carehta is offline   Reply With Quote
Old 03-26-2008, 12:55 PM   #5 (permalink)
sven's Avatar
He's right. All serpentine V8 have a "normal" thread. The older RRCs/D90s with V-belts are the "reversed" thread.
99 D1
73 Series SWB
95 RRC LWB - Sold
Old 03-26-2008, 08:34 PM   #6 (permalink)
Carehta's Avatar
I keep my promise to help. Am confirming I removed the Disco I 96 GEMS engine viscous fan with a counterclockwise hit in a 36 mm open ended wrench (the beast is right hand threaded). The viscous pulley can be stuck which requires greater power. You prevent the water pump pulley to spin, put a strong screwdriver across the axle, touching one of the 3 pulley bolts with the tip. You may use less effort not pushing the screwdriver with the left hand, so you better to sit the screwdriver handle in a 15 mm socket plugged in the belt tensioner bolt to make the necessary leverage.
96 D1
93 110 tdi
Old 03-27-2008, 10:33 AM   #7 (permalink)
AFIROVER
afirover's Avatar
hey I'll be in your village on monday ill bring my stuff and undo that junk for if you like
afirover is offline   Reply With Quote
Old 03-27-2008, 10:41 AM   #8 (permalink)
ultrrunr's Avatar
There is such a tool as a pulley wrench for using in such cases.....
Lisle LIS28500 Strap Wrench - Toolfetch.com
Craftsman 2 pc. Strap Wrench Set - Model 45570 at Sears.com
Good luck.
ultrrunr
"Life's Tough, it's even tougher if you're stupid." - John Wayne
ultrrunr is offline   Reply With Quote
ACE removal idea that might work deja7654 Discovery Series II 11 11-07-2007 06:33 AM
Removal of alternator 97 Disco.... timkel74@msn.com Discovery Series I 2 10-12-2007 02:44 PM
Heater, coolant leak question for 2000 P38 Dburgoyne Range Rover P38, Mk III and Range Rover Sport 8 02-23-2007 02:47 PM
Removal of side steps/running boards gregoire76 Discovery Series II 4 11-13-2006 05:37 PM
Replacing heater o-rings and servo gbvilla Range Rover P38, Mk III and Range Rover Sport 5 05-16-2006 07:59 PM
