Old 10-03-2008, 09:16 AM   #1 (permalink)
Exclamation Faulty code 42 in my Disco 94
Hello, I'm new in this forum. Greetings
Í've been having a problem with my ride, since the las time i took it to the mechanic, the yellow check engine light remains on, and there was a 44 code. I checked the oxigen sensor in the left bank and replaced it. I cleared the codes and started the engine again and after 10 min the light came on again but this time the panel registered an 42 code but I can't find out what is that. I'm also having problems with the sensor that controlls the minimum, I don't know the name of it but is located in the rear part of the intake, near the firewall, is scrwed and has 4 pins connector. Can I have some tips to test it?
Thanks folks!
Bryan
dobrati is offline   Reply With Quote
Code 1176 Maximum Positive FMFR Correction Fault Disco I wade Discovery Series I 9 04-24-2008 03:14 PM
code list for Seris I Disco code 44? 97DiscoXD Discovery Series I 3 02-23-2007 06:56 AM
95 disco check engine light code 17 JeffinIA Discovery Series I 3 11-04-2006 01:10 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
Discovery Tech Questions 62sunbeam Discovery Series I 9 12-22-2004 11:05 AM
