Old 03-03-2005, 08:32 PM   #1 (permalink)
Default is fender trimming really needed?
Well I was told that if I wanted to install 32''x10.5'' tires or anything larger that I would need to trim the fenders, if I didnt want the tires to rub against the fenders or get stuck when the wheels tuck in. Please tell me this is not true. I dont want to try to trim my fenders and end up messing up my truck and I dont know of anyplace around the San Francisco Bay Area that would do it or atleast trust to do it. The thing is I just had a 3'' lift and want to put larger tires now, but I was recomended not to go higher than 31'' tires. If it is needed for larger tires please let me know.
RickyRover is offline   Reply With Quote
Old 03-03-2005, 10:27 PM   #2 (permalink)
http://www.disco2.com/howto/offroader/tyresizes.phtml
this is the best info on tyre sizes i've been able to find for the disco ii.
99 disco ii w/ cold climate and SLS.
plastic is offline   Reply With Quote
Old 03-03-2005, 11:00 PM   #3 (permalink)
Thanks but unfortunately I drive a 1997 Discovery I SE
Old 03-04-2005, 05:41 PM   #4 (permalink)
AdrianS's Avatar
Ricky,
You don't have to trim if you are going to use the stock rim but you will have to adjust the rear fender a little. If you look under the fender right behind the rear tires you will see a small screw. Remove it and the little bracket and carfully pull the fender well out about an inch then bend the bracket in to a "Z" and put it back. This will work with 265's and 235's on stock rims. You will also have to adjust the front steering stops to keep the tires from rubbing on the radius arms at full lock. Hope this helps. We have done this to my 98DI and my buddies 95 & 96DI.
Adrian Strata
www.4x4ag.com
98 DI
34x10.50 Simex JT
2.5" SR lift
Evo Kit
91 RRC parting out
AdrianS is offline   Reply With Quote
