Before I take it apart, when the oil from the Swivel ball is leaking from behind the rim, which seal has gone? The one within the stub axle?
I also need to replace my swivel ball seal to the axle housing as the oil is also seaping through that one.
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD Dsl - Wilks www.TerraTrekker.com
Mike, while I do agree on the grease comment, after using it once decided not to refill with grease being that most of the off roading done down here is done in water/mud...so even with new seals, water will find its way in there. Oil is a lot easier and quicker to drain and refill. I've tried the 50/50 mix but its not worth the hassle...Oil all the way.
Leaky swivel ball seals can also be insufficient swivel bearing pretension.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc. |
#5 (permalink) | |
