Some may have seen my threads last august or september about my disco being dead and now, finally, it works again.
THE PROBLEM: it overheated due to rapid coolant loss. it leaked out of the seam around the middle of the coolant tank. (very seemingly insignificant part to kill the whole engine) THE RESULT: heads warped block, crank, pistons, and heads overheated beyond repair THE OPTIONS: 1. pay land rover somewhere over $14,000 to fix it. (that was the estimate they gave me, but they only accounted for the block being replaced, not everything else) 2. pay a local non land rover shop $4,500 to put a used engine in 3. do it yourself because youre better off buying another disco than going with option one or two so i chose option three. it took so long cause i was off to college and couldnt work on it much until i got out for the summer. so i pulled everything out and then put it all back in, except i pretty much replaced everything. i bought: a block, rods, pistons, crank, bearings, rings, crower cam, lifters, timing set, water pump, coolant tank, spark plugs, head bolts, all hoses, all gaskets, belt, and a battery. the heads were inspected, complete valve job done, theyre all good now then i put it all together, had some hydraulic lifter tapping noise for a little while after crank up but it went away and now its running great. im still in the breakin period so i havent seen how the oversized cam feels with the pedal down yet. (115/500 miles) saved a lot of money and learned a lot. ive got tons of pics on my camera so ill upload some after i put them on the computer if anyone wants to see. |
congrats.....much better than shelling out a testicle. plus, now your edumacated about engine works and future repair bills will be minimal.
as for the lifter noise at first.....normal priming! in the future you can soak them in a bag of oil first to help decrease this. im anxious to hear about the crower cam power results as i am contemplating this on my current top end rebuild. enjoy! |
which Crower cam? and did you go with roller lifters?
$14K!! Anyone can pick up a catalog and find a rebuilt engine for $3k. What did the dealer want to do? And, like Flunkster, I'm happy to hear that you still have your testicles.
'95 Disco, 103k miles, stock, but needs a little work. |
my memory card finally filled up so i dumped all my pics on my computer and so i put a few of the rebuild online if anyone wants to see
http://picasaweb.google.co.jp/dmore6/Rebuild the dealer said a new block was 10k, i would be charged a 2k core charge cause they couldnt use my block, then 2k for labor. so that doesnt even include all gaskets and the head work and everything else |
#5 (permalink) | |
'97 Disco
Forward!
Good job on the motor rebuild.
Just curious what your final total is, as this job I am sure is in my future. ![]()
1997 Disco 1 2000 Disco 2 1989 RR(gone but not forgotten )Miami Valley Land Rover Society www.mvlrs.com ON WISCONSIN |
Well done Disco1... Its always great to hear that someone was able to complete a job themselves. If you think your cost was higher than expected, remember that you learned plenty - you probably gained a couple of grand worth of experience!
Cheers. |
the total was about $2200 i believe.
pavel i definitely agree. i know so much more than i did before all this, it was a very good learning experience. i did not get roller lifters, cam intake: duration: 258 deg lift: .430 exhaust: duration: 260 deg lift: .445 |
#9 (permalink) |
cool on the rebuild. Let us know how that cam is after you break it in. Take it to the dragstrip and let us know whether you can complete the 1/4 mile before you fall asleep...hehe.
| Thread Tools | |
| Display Modes | |
