Old 05-29-2007, 09:05 AM   #1 (permalink)
Disco 1's Avatar
Default Finally
Some may have seen my threads last august or september about my disco being dead and now, finally, it works again.
THE PROBLEM:
it overheated due to rapid coolant loss. it leaked out of the seam around the middle of the coolant tank. (very seemingly insignificant part to kill the whole engine)
THE RESULT:
heads warped
block, crank, pistons, and heads overheated beyond repair
THE OPTIONS:
1. pay land rover somewhere over $14,000 to fix it. (that was the estimate they gave me, but they only accounted for the block being replaced, not everything else)
2. pay a local non land rover shop $4,500 to put a used engine in
3. do it yourself because youre better off buying another disco than going with option one or two
so i chose option three. it took so long cause i was off to college and couldnt work on it much until i got out for the summer. so i pulled everything out and then put it all back in, except i pretty much replaced everything.
i bought: a block, rods, pistons, crank, bearings, rings, crower cam, lifters, timing set, water pump, coolant tank, spark plugs, head bolts, all hoses, all gaskets, belt, and a battery.
the heads were inspected, complete valve job done, theyre all good now
then i put it all together, had some hydraulic lifter tapping noise for a little while after crank up but it went away and now its running great. im still in the breakin period so i havent seen how the oversized cam feels with the pedal down yet. (115/500 miles) saved a lot of money and learned a lot. ive got tons of pics on my camera so ill upload some after i put them on the computer if anyone wants to see.
Disco 1 is offline   Reply With Quote
Old 05-29-2007, 12:40 PM   #2 (permalink)
flunkster's Avatar
congrats.....much better than shelling out a testicle. plus, now your edumacated about engine works and future repair bills will be minimal.
as for the lifter noise at first.....normal priming! in the future you can soak them in a bag of oil first to help decrease this.
im anxious to hear about the crower cam power results as i am contemplating this on my current top end rebuild.
enjoy!
flunkster is offline   Reply With Quote
Old 05-29-2007, 01:50 PM   #3 (permalink)
which Crower cam? and did you go with roller lifters?
$14K!! Anyone can pick up a catalog and find a rebuilt engine for $3k. What did the dealer want to do?
And, like Flunkster, I'm happy to hear that you still have your testicles.
'95 Disco, 103k miles, stock, but needs a little work.
DenverCurmudgeon is offline   Reply With Quote
Old 06-13-2007, 06:47 PM   #4 (permalink)
Disco 1's Avatar
my memory card finally filled up so i dumped all my pics on my computer and so i put a few of the rebuild online if anyone wants to see
http://picasaweb.google.co.jp/dmore6/Rebuild
the dealer said a new block was 10k, i would be charged a 2k core charge cause they couldnt use my block, then 2k for labor. so that doesnt even include all gaskets and the head work and everything else
Old 06-13-2007, 07:17 PM   #5 (permalink)
Buddy Lee's Avatar
Wow that's just insane what was that guy smoking. For that kind of money you could have paid someone to convert you to a diesel. I think you could have found a used low mileage engine for under 2,000 if you looked around a little bit. But the rebuild sounds like it worked out for you.
'97 Disco
Buddy Lee is offline   Reply With Quote
Old 06-14-2007, 03:44 AM   #6 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Good job on the motor rebuild.
Just curious what your final total is, as this job I am sure is in my future.
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Old 06-14-2007, 09:34 AM   #7 (permalink)
pavel's Avatar
Well done Disco1... Its always great to hear that someone was able to complete a job themselves. If you think your cost was higher than expected, remember that you learned plenty - you probably gained a couple of grand worth of experience!
Cheers.
Visit my j**p website
Old 06-15-2007, 10:51 PM   #8 (permalink)
Disco 1's Avatar
the total was about $2200 i believe.
pavel i definitely agree. i know so much more than i did before all this, it was a very good learning experience.
i did not get roller lifters,
cam
intake: duration: 258 deg lift: .430
exhaust: duration: 260 deg lift: .445
Old 06-16-2007, 05:54 AM   #9 (permalink)
cool on the rebuild. Let us know how that cam is after you break it in. Take it to the dragstrip and let us know whether you can complete the 1/4 mile before you fall asleep...hehe.
jhmover is offline   Reply With Quote
