I have driven my 98 Disco for over 160K miles. Today was the first time I have ever had to pull it over on the side of the road. Sad, just simply sad.
Coming home from a day out with the family (Ikea). It suddenly just started putting along. Slowing Slowing Slowing... to a crawl. I could let it idle and it would roll on its own but to give it gas only made things worse. I could let it set for a while and start it up... pull away like nothing was wrong... then putt putt putt. We did get stuck in stop and go traffice for a while before it started this crap... No codes, no pending codes.... Tranny fluid looked good, oil clean as ever... no over heat, no smells... nothing. It will start right up and idle for a bit... after a while with revs it would peter out again. Let sit, and start all over. I think it is starving for fuel... I am going to change the fuel filter this evening and see what happens. Anything else I can look at??? Damnit, I dont have any codes... those things atleast point you in a direction. I hope it is not the stinking fuel pump. Well then again, better that than something internal (engine). Thanks for any tips. Richard
That is not a leak! That is undercarriage rust inhibitor. 98 Discovery |
Elephantitis penisitis
There's yer problem right there...IKEA???
My money is on the fuel filter.
Check your fuel pressure - on the fuel rails where your injectors are - its goning to be on the left side, there should be a cap that looks like the cap on your tire - screw it off and then push your finger or whatever to see if gas sprays out if it sprays then you got pressure, also let it run a little bit - dont do it when it was sitting all night warm it up a bit if you still can
GooD Luck |
leave the fuel pressure gauge on to see if it drops when it dies.
I suspect it wont. In fact it should stay the same for the entire time it starts and dies. You could have a problem with the stepper motor. |
![]() Join Date: Dec 2005
I wonder..........no maybe I don't, I believe there is a relay for the fuel pump, and maybe, just maybe, not sure, the MAP sensor is messing up to the point where it allows the truck to run, but at this point shuts off the fuel pump relay. Similar thing happened on other fuel infected, er um fuel INJECTED vehicles,
but look into that, the computer probably wouldn't get a code from it neither.Also check for the basic things, you know what they are, fuel, spark, air, etc.. Good luck man
Well, I went for a little drive late last night to pick up the fuel filter... damn thing ran like nothing was wrong. I changed the filter anyways to be sure... will test it out this afternoon.
#7 (permalink) | |
![]() Join Date: Jun 2005
"Ish...I have in the past mistaken you for a perverted shit bag...now I realise that I am not shit bag enough. You truly are a king among men.I am not worthy with such imagination." Series 3 Guy 2005 Range Rover HSE 2007 BMW X3 M Sport Pkg 1990 911 Cabrio triple black 2006 Mini Cooper S Checkmate - GONE 1987 Corvette - 18 yrs Gone,,, sniff sniff - |
You might be right about that... it has lasted me many miles.
I suppose it would not hurt to change that out seeing it has given me plenty of travel till now. I was curious if the pump could began to fail without stalling the engine... maybe only fail maintaining higher demand. Even at it worse yesterday, it would idle just fine and coast but when I touched the gas it began to pudder. I will certianly look into that. Thanks.
#9 (permalink) |
How long does a fuel pump usually last?
#14 (permalink) |
Sorry it took so long to get back to this...
I did change out the filter. The gas from the filter looked like old tea. I put a bottle on the end of the hose to catch some fuel, cycled the pump, it came out clean. I guess I pulled the big dumbass neglect on the filter. I have had it out several times on the highway running 70 for a few miles but nothing like the trip to hell (Ikea) I took last week. Hopefully the filter will do the trick this time. Maybe I dodged a bullet on this one. Thanks for the input guys, I have my eye on that pump though. If this pump does go bad is it all or nothing or can I catch the symptoms early?
#15 (permalink) |
Magicly Delicious
glad it was just a filter. if i were you i would run a good sized dose of injector cleaner.
Kevin Owning a Land Rover is like dating a super model. Sure she has expenive tastes, complains a lot, and requires constant attention... but damn... 1994 Discovery |
