Old 01-17-2006, 08:32 AM   #1 (permalink)
Default Flow meter Ohm
The check engine ligth it on and when I take the(read out code) code is Oxigen sensor code second bank.I bought all of them(4).But the light it on again.
I want to know the mesures in omh from the flow meter? To figure out if is the flow meter,and smell like bad combustion .If need some information just ask me.
learn is offline   Reply With Quote
Old 01-17-2006, 09:00 AM   #2 (permalink)
Banned
What did you just say?
Hank is offline   Reply With Quote
Old 01-17-2006, 10:29 AM   #3 (permalink)
So what year and mileage are you working with, this really helps????
Mike J.
Old 01-18-2006, 03:12 AM   #4 (permalink)
I just want the measure (omh)of the flow meter mines has 3 pins. 1996 disco 1 with a 4.6,:wave,2003 -2,300 miles
Old 01-18-2006, 03:19 AM   #5 (permalink)
I do not say nothing.I just ask a guestion (?) measure in omh of the flow meter.If u do not understand please do not replay, Better go to u bed it's late 6:30 pm .
Old 01-18-2006, 10:39 AM   #6 (permalink)
bluemax09
OK...I'll bite on this one.
When your check engine light comes on and you replace the faulty part as per the code, your light will not automatically shut off. It may take several days for it to turn off or you may even have to take it back in and have them run another diagnostic on it. When they find no faults they will manually shut the light off.
bluemax09 is offline   Reply With Quote
Old 01-18-2006, 11:36 AM   #7 (permalink)
Banned
you english really bad maybe if understand me could help
What codes are you getting, in numbers? Does the truck run right? Are you getting smoke at full throttle?
If it's a 96 with a 4.6L motor, are you using a GEMS management system?
