Old 02-11-2007, 08:40 PM   #1 (permalink)
Default FNG here with questions.....
Hey everyone I just purchased a 92 classic and love it although it does have it's flaws....one is the hood flaps up on the passenger side while driving on the highway but does stay locked, does anyone have a fix for this? Also there are several cluster lights on ie...check engine- but runs flawless, also ebrake, and water level I believe but it's full of fluid...any help would be much appreciated....just looking for a starting point on some of this stuff like if is a common problem with these things....thanks
CATMGuy is offline   Reply With Quote
Old 02-11-2007, 08:50 PM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
Welcome to the 92 Rover club..... The hood only has a center catch...Make sure it is shut all the way and the hood release pushed in...If so there are adjustible stops on each corner...Adjust those to get even tension and you will be fine.....
When I first bought mine the coolant light was always on.... The connectors on the reservoir were bad..Replaced those and the problem went away.
Old 02-11-2007, 08:53 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
Also.. E-brake..On a friends classic it was a connection at the actually hand brake we repaired.... CHK engine.. could be a lot of things...
Old 02-11-2007, 08:58 PM   #4 (permalink)
Hey thanks for the help....I really appreciate it...I will try that stuff tomorrow...Is there a place to plug in a code scanner on these so I can check the check engine light?
Old 02-11-2007, 09:08 PM   #5 (permalink)
Rocky Mountain High
Funrover's Avatar
Not sure about TX....... I go to a local independent rover shop...... You may try the Texas rovers club website and see if they have any info about where to go!
